D Grader Transmission Parts
Ken in Texas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Topic: D Grader Transmission Parts
    Posted: 19 Apr 2014 at 6:29am
Where is a good source for used D grader Transmission Parts?  Restorer can furnish part numbers of needed water damaged main shaft gears.
Ages Cat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ages Cat Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2014 at 8:22am
Someone from Wichita Falls told me last week he has a catalog which is exclusively AC D parts. The company is located in Florida. The connection was bad and I did not get the name.
d9gdon View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote d9gdon Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2014 at 9:51am
Some of them aren't gonna be easy to find if they're like my M65 grader which was built right after the D.
Do you have the parts book? Here's one you can download:
http://www.minnpar.com/manuals.asp
You can find used ones here if you have the part numbers:
http://www.machinerytrader.com/list/partssearch.aspx?PartNum=70059942&btnPartSearch=Search&PST=Starts
You can plug your part number into this website, MinnParr. They bought the parts inventory from Fiat Allis and can supply some new parts. Get your checkbook ready when you price them. For instance, plug that same gear number (70059942) into their website for a shock.
http://www.minnpar.com/partlisting.asp
Good luck and if you run across any used transmission gears for a M65, let me know.
Edited by d9gdon - 20 Apr 2014 at 10:06am
This page was generated in 0.230 seconds.
