Crankshaft Question
IL-D17 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IL-D17 Quote  Post ReplyReply Direct Link To This Post Topic: Crankshaft Question
    Posted: 14 Apr 2014 at 3:32pm
Is there any difference between 226 crankshafts from a by-pass filtering system and a full pressure filtering system?
cotncrzy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cotncrzy Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2014 at 4:16pm
Yes, journals are wider I believe.
C, WD45,WD puller, 185, 200, 7060 Red Belly, 7060 Black Belly,8010, and a R52 Gleaner, AND PROUD OF THEM!
wi50 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wi50 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2014 at 4:50pm
Early engines like the WD45 by pas system had the small main journal crank, thrust bearing in front.
The later D-17 engines all have the same crank dimensions, weather it be the earlier by pas oiling engine or the later full pressure engine.  All had the large main cranks, and all those cranks have the same dimensions.  Thrust bearing in the center.
There was some surface treating in the late 226 cranks.  Nitride treatment.  Ever notice how the center main is worn on the side opposing the throws while the side of the main journal closest to the throws isn't worn nearly as much.
Post Options Post Options   Thanks (0) Thanks(0)   Quote IL-D17 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2014 at 7:38pm
Thanks for the replies fellas! Reason I ask is I'm wanting to switch from by-pass filtering to full pressure. I've found a full pressure block and pump and was hoping I could put my current crank in the later block. Is it possible to convert a by-pass block to full pressure without much work? I've also heard the later D17 blocks are a little meatier inside than the early ones and in turn requires more grinding or machining to clearance added stroke. Is this true?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2014 at 7:45pm
Series 4 D-17's were the start of the "Tufftrided" crankshaft journals on the G-226 engines. Those are A-C's words, not mine, taken from page 5 of a D-17 IV brochure dated Sept-1964. The later models One-Seventy and 175 also had the same feature. 80% to 90% of the time when overhauling one of those, I never had to regrind the crankshaft at the first OH. I always installed -.001" undersized main bearings and used standard rod bearings and back together she went. If they got any maintenance at all, those crankshafts didn't wear much by time for the first overhaul.
patrickmull View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote patrickmull Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2014 at 9:41pm
I am going to do it to mine it will take some machining but it can be done
mattb View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mattb Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2014 at 8:48am
I put a full flow oil pump in a wd45 block it worked fine just have to make sure your cam gear matches ur pump gear is where the difference is has 40psi now.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2014 at 10:40am
A full-flow pump doesn't give you full-flow filtering until you drill the block and plumb the different oil filter base and lines.
Post Options Post Options   Thanks (0) Thanks(0)   Quote patrickmull Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2014 at 3:51pm
you have to plug 3 holes take out the relief valve drill and tap the plug  drill out and tap the hole back into the block use the new style lines and filter base
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2014 at 11:27pm
Rather easy to convert bypass to full flow.Did it to my 45 after a discussion with DrAllis as to the particulars.Simple once you understand.
Post Options Post Options   Thanks (0) Thanks(0)   Quote patrickmull Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2014 at 5:38am
I did mine yesterday it is easy to do
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2014 at 7:46am
I did one recently on a WD-45 for myself and was able to use the threaded portion of a 12MM coarse bolt as the blocking slug (cut a slot in one end for a flat blade screwdriver). After installing it with Loctite in the vertical passage, I was able to rethread the engine block and reinstall the original oil pressure feed line connection without using any oversize pipe thread bushing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote patrickmull Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2014 at 9:39am
i made a blocking slug on the lath for a tight fit and used sleeve retainer epoxy to hold it in place
This page was generated in 0.115 seconds.
