HD5/6 sterring clutch assembly
Ages Cat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ages Cat Quote  Post ReplyReply Direct Link To This Post Topic: HD5/6 sterring clutch assembly
    Posted: 13 Apr 2014 at 10:26pm
We are assembling  steering clutches on an HD5B. The book calls for "Supremalube or an equivalent" to be used on assembly. I am unfamiliar with this  product. Can someone Please educate me?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2014 at 9:17am
? Where is this called for to be used ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ages Cat Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2014 at 1:36pm
i am assuming where the teeth make contact with the drum. it is very vague as to the specifics. The  HD6 manual wording is similiar.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ages Cat Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2014 at 6:02pm
Quoting Service  manual: "Lubricate hub teeth with Supremalube or its equivelant".
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ages Cat Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2014 at 8:20am
I spoke to several people regarding this assembly process and the consensus is  use Hi-Temp anti seize compound.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2014 at 3:13pm
this must be on metal plate teeth to the inside drive hub .
I never did lubricate any of these as it seemed on most machines i flushed the clutch housing and plates with diesel by installing plug in case drain and adding 5 gallons of diesel then running machine and operating clutches to flush them and free them of any trash or oil.
