Allis Chalmers M65 Motor Grader
d9gdon View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote d9gdon Quote  Post ReplyReply Direct Link To This Post Topic: Allis Chalmers M65 Motor Grader
    Posted: 12 Apr 2014 at 4:42pm
I just bought an Allis Chalmers M65 motor grader and I'm looking for some transmission gears and shafts for it. The serial number is 24A10xx.
I would be interested in buying a parts machine or finding one in a junk yard somewhere to buy parts off of.
I have found most of the bearings and spacers thru Minn Parr. I'm still in need of the reverse gear, the first and second gear combo, and the top input shaft gear. I have also tried Machinery Trader and Rock & Dirt parts. I will be calling the dismantlers listed on there during the coming week. Do the later Fiat Allis M65 BPE serial numbers use the same parts?
Can I get the parts drawing to have them made as a last resort?
Thanks for any help that you can provide.
Post Options Post Options   Thanks (0) Thanks(0)   Quote d9gdon Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2014 at 11:47am
Correction on the later M65 serial number of BPE, that is not a good serial number.
dpower View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dpower Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2014 at 1:18pm
Well we have like a 74 M65 grader which someone put a different radiator in it. If you happen upon a parts machine or radiator and don't need one yourself let me know Id be interested in buying it from you.
Post Options Post Options   Thanks (0) Thanks(0)   Quote d9gdon Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2014 at 3:48pm
I will do that, dpower.
