hd6g tips or tricks? |
wildbill26
Joined: 25 Sep 2010 Location: claysville,PA Points: 534 |
Topic: hd6g tips or tricks?Posted: 12 Apr 2014 at 5:51am |
I have a friend who.owns a hd6g, he has never run heavy equipment I have run mostly cat 955, any tips or tricks to know about operating one? I will be using it to haul wood, in the bucket and cut in a driveway also, thanks
1950 wd wide front w loader
1940 b, 1939 m crawler |
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42268 |
Posted: 12 Apr 2014 at 12:11pm |
DON'T use main clutch as a slipping clutch - in or out , use steering clutches for control.
Set throttle for speed and leave it - unless it has decelerator. Hope it has counterweight - carry load low when traveling - any machine ! Don't try to move a mountain with the bucket , start cut and fill bucket while moving , shave the material - not brute force into it. Will push more than it will carry.
Edited by Coke-in-MN - 12 Apr 2014 at 12:13pm |
wildbill26
Posted: 12 Apr 2014 at 1:28pm |
Thank you coke, unfortunately it dosnt have a counter weight, the decelirator is that the pedal between the brakes ?
Coke-in-MN
Posted: 12 Apr 2014 at 7:23pm |
Unsure on that machine - center pedal is normally for applying both brakes at same time as well as engaging steering clutches to stop all power to track.
wildbill26
Posted: 13 Apr 2014 at 6:28am |
Thank you coke, I had thought it was a brake, I ordered an operators manual since he didn't get one, and he cant run it, ill make sure to post.some pics when I get started
HD6GTOM
Posted: 15 Apr 2014 at 9:28am |
center pedal on all I have used is decelerator pedal. Take it slow, they are not a high speed machine, do like coke says. He will be a very busy guy with all the hand controls.
Coke-in-MN
Posted: 15 Apr 2014 at 3:55pm |
Dang might have to try a HD6 some day - My HD5G and my F/A FD5 are different machines in many ways but once you run any machine it becomes easy .
Well except for when I had the HD4 - it seemed I got my feet and hands crossed up all the time .
michale34
Posted: 16 Apr 2014 at 10:14am |
my hd6g has a decal pedal in the middle they were used on the new style hd6gs with the 6000 engine my dad call them high seaters now the couple of low seat had6g we had with the buda engines didn't have the pedal just the throttle just like the hd5g
wildbill26
Posted: 16 Apr 2014 at 6:25pm |
thank you all for the replies
