wd
Ronnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ronnie Quote  Post ReplyReply Direct Link To This Post Topic: wd
    Posted: 11 Apr 2014 at 11:46am
I have a wd bone stocke i am planing on pulling the gov dosnt seem to go very high i was wondering if there is a way to adjust it or change it to get more out of it
bigcountry48 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigcountry48 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2014 at 2:02pm
D17 governor springs
1950 B, 1952 pulling wd, and 1954 wd45
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ronnie Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2014 at 5:04pm
Ok thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ronnie Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2014 at 5:53pm
Im just wondering if i could use a carb off a 2500 gas engine and put on the wd
56allis_msu View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 56allis_msu Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2014 at 11:43pm
Make sure all your throttle linkages are goof and tight. Over the years they begin to wear into one another which can cause a lot of slack and a drop in rpm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ronnie Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2014 at 7:34am
There is a very good amount of slop in linkages. Whats the best way to fix all of that?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ronnie Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2014 at 9:19am
So can i use a 2500 gas engin carb on my wd
Mrgoodwrench View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mrgoodwrench Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2014 at 9:25am
not an expert but that seems like way too much carb for a 201
There are 3 ways to do job GOOD, FAST, CHEAP. YOU MAY CHOOSE 2. If its FAST & CHEAP it won't be GOOD, if it's GOOD & CHEAP it won't be FAST, and if its GOOD & FAST it won't be CHEAP!!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2014 at 1:12pm
#1. The carb from a G-2500 from a One-Eighty is different than a carb from the G-2500 in a One-Ninety. #2. Neither will bolt on to your manifold as the bolt pattern is too wide. #3. Even if you managed to get it bolted to the manifold, you'd have to rework/modify the throttle butterfly lever to fit your engine. #4. Pretty sure it would require an electric fuel pump to keep fuel in the bowl.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ronnie Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2014 at 8:13pm
Ok i was just wondering thought i c if it would work im just going to put d17 g springs in and c how it does it seems strong gust no rpm
This page was generated in 0.138 seconds.
