HD 41 and other tracked machines
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Topic: HD 41 and other tracked machines
    Posted: 08 Apr 2014 at 9:42pm
they featured tracks at Pioneer Power, Albany, MN last September
Allis hd41 carrying a Cletrac F, Cat 10 with hand lift dozer on the back. Allis on top and a Vaughn WS on the ground.
 marv in minn
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2014 at 7:06am
Cool picture!  I was lucky enough to see a 41B at work in PA a few years ago. It is a beast!
Andrew_D View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Andrew_D Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2014 at 8:52am
What's going on with the far corner of that blade? Looks like the corner is torn up? Or maybe I need another cup of coffee before I look at it again?
Andrew
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2014 at 7:11pm
Looks like it needs some remedial sledge hammer and buzz box work...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2014 at 8:26pm
At the time the mine owner was running about 8 or 9 41's with another 20 or so parts machines.      This 41B was almost 40 years old and was in need of some TLC. It was working with a D-10N which looked small beside the 41B.  I was told that the mine was sold a few years ago and all the 41B's were scrapped out by the new owner.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2014 at 9:18pm
the dozer blades get thin on the front and the fix was to add 5/8 inch thick rolled plates to the front and weld on. You can see the added plates in the picture. They only go about 2/3 of the way up the blade. If you look on the left corner you can see the lower edge is starting to wear thru again and collect dirt... On the right the cover plate has actually worn all the way thru and the thin edge has started to roll out away from the blade.  Thats not uncommon when the cover plate gets worn down to 1/8 inch thick. Not much can stand up to 500 HP and 80 tons of tractor.
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2014 at 9:24pm
I gotta run one of them beasts before I die. Guess you could say that "running an HD41" is on my bucket list. Darrel
chumduffy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chumduffy Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2014 at 7:32am
We had a FD50, it was a real monster!!! We have a TD 40C Drestta now for our big tractor but it not the same. I miss the FD50!! I liked it, until it was stuck!!    Chum..
Post Options Post Options   Thanks (0) Thanks(0)   Quote chumduffy Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2014 at 9:34pm
Here is a picture of my Daughter Jamie and I we just moved our FD50 onto a coal reclamation job in Slippery Rock,PA and yes shoveling the tracks every night in the winter really stinks!!
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2014 at 1:34am
75 or 80 tons of machine?
  That was a nice looking machine there.
Nice pics...
