B110 and tiller setup
LionelinKY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LionelinKY Quote  Post ReplyReply Direct Link To This Post Topic: B110 and tiller setup
    Posted: 04 Apr 2014 at 6:24am
A couple of questions for those that have done it before.
1)What are the belt sizes I need since my parts book doesn't tell me? I need both belts width and length. One belt from the BGB drive to the tiller mule system. Second belt runs from the mule system to the tiller itself. Just to clarify, this is my first attempt ever at mounting an AC tiller. Dad gave me tractor last year and tiller was something he found at auction but never mounted either. Thus, I don't even have the luxury of old belts to measure-totally starting from scratch here.
2)Just what is the purpose of the adjustment screw on top of the tiller itself and how critical is it for actual tiller usage? I'm assuming it is a front to back leveling adjustment of sorts. Mine was so rusted and seized that the amount of patience, heat, and rust penetrant I did use was unable to prevent twisting off the bolt. I wound up drilling the bolt(and threads) out of the threaded block. My plan is to use a good hex hold bolt with a nut on each side of the former threaded block to allow for adjustment. Right now though there is nothing there. The tiller is pinned at the drawbar and at the lift as I believe it is supposed to be. As is, there doesn't appear to be much movement for leveling adjustment which is what makes me question a need for this screw adjustment in the first place. Thanks in advance for your help.
Chris/CT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2014 at 7:04am
You need to post what size tiller to help, 32" or 36"???
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2014 at 12:19pm
that adjusting bolt ontop and pivot is what tighens the belt asfor the size of the belts  i would have to look on mine wish icould send you picture of mine give me a call www.tractorandequipmentservice.com
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2014 at 1:56pm
On a 32" the BGB to mule drive belt is AC #2025236 which is 5/8x56.  The Mule to tiller belt is AC 2025641 which is 5/8x42.  As for leveling, there really isn't any. As mentioned, the adjusting bolt is for tightening the mule drive to tiller belt.
AaronSEIA
Post Options Post Options   Thanks (0) Thanks(0)   Quote LionelinKY Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2014 at 7:06am
thanks!!!!!
This page was generated in 0.643 seconds.
