HD3 diesel engine information needed
donw View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote donw Quote  Post ReplyReply Direct Link To This Post Topic: HD3 diesel engine information needed
    Posted: 27 Feb 2010 at 8:42pm
I'm in the preliminary fact-finding stage and am in search of information about the diesel in my HD3. I suspect it may have a blown head gasket because it is starting to overheat easily and antifreeze will spit out the radiator fill hole when I'm cranking it over. I'd really like to pull the diesel and rebuild it. Those of you in the know, what can you tell me about this little 4-cylinder?
Don
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChuckLuedtkeSEWI Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2010 at 8:50pm
Don, what might help you in your search is that it is the same engine as a D15 diesel tractor.   Hope that helps.
norm [ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm [ind] Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2010 at 11:46am
  WORKING PARTS ARE THE SAME AS WD45D  ONLY 4 CYL. CAN HELP
   1-800-254-3116
This page was generated in 0.332 seconds.
