HD11 throwout bearing yoke
Gargoyle View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gargoyle Quote  Post ReplyReply Direct Link To This Post Topic: HD11 throwout bearing yoke
    Posted: 02 Apr 2014 at 10:44am
Serial #8878
I found wear on the right steering clutch throwout bearing yoke (part # 620712). The yoke had been tipping in from the top far enough that it ground on the heads of the steering clutch mounting bolts. There were grooves worn in the yoke about halfway up from the bottom. Not a good place for wear..
I found some wear on the ball at the top of the yoke. I replaced the bushings for the trunnion pins. The throwout yoke wear pin at the bottom did not appear to have much wear, but I don't know how thick it was originally.
Anyway, I don't see any other way to limit the travel of the yoke to prevent it from grinding on the bolt heads.. Any advice?
This page was generated in 0.426 seconds.
