Is there a trick to removing vbelt on D17?
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChuckLuedtkeSEWI Quote  Post ReplyReply Direct Link To This Post Topic: Is there a trick to removing vbelt on D17?
    Posted: 27 Feb 2010 at 8:10pm
Was tearing into the D17 for a bit tonite and I got the generator off to fix the rear bearing and was looking at replacing the belts as long as I was this far.  Problem was I couldn't seem to find a way to get the v belt around the double pulley for the generator/water pump and the power steering pump.  These belts seem pretty worn, and they still don't want to go between the crank pulley and the back of the front bolster.  There is some grease/grime built up inbetween but I didn't think there was that much!!
kbeatty View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kbeatty Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2010 at 8:18pm
pully has slipped forward the set screw proably has loosened mine doe the same thing
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChuckLuedtkeSEWI Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2010 at 8:54pm
thanks, that would explain the belt wear.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChuckLuedtkeSEWI Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2010 at 11:59am
I turned the engine over and pulled out the set screw which was tight and the threaded hole on the pulley and the tapered hole in the crankshaft line up perfectly so that isn't it.  I will have to check on how much gunk is built up between the pulley and the front bolster when I get home later.
jrjuday View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jrjuday Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2010 at 12:49pm
I usually cut the old belt and drive the new one through the gap with a BFH and long drift. Just not much room in there!
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChuckLuedtkeSEWI Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2010 at 7:20pm
Ok, sounds like a plan.  I will cut both off and try to get them matched up this week.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2010 at 9:43pm
Chuck - that set screw on the crank belt pulley is REAL important to get right and tight.  Mine came loose on my Series IV and ruined the end of the crank and it couldn't be rebuilt...ended doing a full engine rebuild out of the deal with another good used crank...probably a good thing though as a I had bottom end deck erosion at the sleeve o-rings on #4 and the oil pump shaft had cracked.  Mike
1968 Gleaner EIII w 10' & 330
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
1956 All-Crop 66 Big Bin
skipwelte View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skipwelte Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2010 at 4:56pm
When you have the double crank pulley on a D17 its almost impossible to get the belts between the pulley and the front bolster.   the BFH and the long drift and lots of 4 letter words seem to work, cause it aint no fun tryin to get the belts back thru that little space without runining something.  Good luck!!
Dave(inMA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2010 at 5:59pm
And I'll bet that the repair manuals say something like "reinstall fan belts" with no real guidance! LOL
WC, CA, D14, WD45
BillyL(SC) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BillyL(SC) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2010 at 7:15pm
The sleeves that the belts come in from one of our boat engine makers have warnings on them not to remove or replace the belt with the engine running.I have rolled belts over tight pulleys by turning the motor over but never seen anybody try to change a running V-belt.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2010 at 7:50pm
Billy, I am struggling with the mental picture of some poor demented mechanic trying to remove or install a v-belt on a running engine. I can't make it work - boggles the mind! Certainly raises an interesting question about the boat engine maker's view of the mechanics working on its engines!!!
WC, CA, D14, WD45
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2010 at 8:11pm
Someone sent me a video(maybe a youtube ?) of a guy who easily removes AND installs the vbelt on a VW beetle with the engine running !! Don't know where it is,maybe goggle for it, but everytime I played it my fingers cringed !!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote BillyL(SC) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2010 at 8:46pm
I have heard stories of it being done but I can't imagine the guy that looks at the belt in his hand then the running engine and has a light bulb go off in his head."Hey why should I waste the time to shut this thing down?"
diamondc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote diamondc Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2010 at 10:28pm
someone emailed me a clip of a guy changing a belt with the motor running. looked pretty scary
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2010 at 11:38pm
legn4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote legn4 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2010 at 12:02am
Chuck there is a belt on the market not sure of name . But it goes together in sections(1 1/2" long) there is a tee slot & twist a 1/4 turn you can made a V belt any length.I have used it on a couple of thing that was going to be a bear to take apart. They are red in color & I think I got it from a place that sold industial stuff (bearings  belts) etc. HTH
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2010 at 5:52am
Just watched the video CTucker posted - pretty clever, but there's no radiator OR fan in the way! My D14 sports a belt like legn4 describes. Was on it when I bought it. So far, so good! My opinion is that it doesn't have the gripping power of a v-belt, but getting a v-belt on it would mean removing the drive shaft for the crank-driven hydraulic pump.
WC, CA, D14, WD45
Rawleigh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rawleigh Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2010 at 8:15am
http://www.mcmaster.com/#v-belts/=687li3
Edited by Rawleigh - 15 Mar 2010 at 8:16am
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChuckLuedtkeSEWI Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2010 at 6:46pm
Well, I got pretty good at taking them off and putting them on.  Cut the old two off, and matched them up at Napa and came back home.  Put the power steering one on, that one was fine.  Took a long piece of 1/8" x 1" flat stock about 3' long and rounded the edges and hammered it through the small space.  Next belt went on which we had the number off of the old belt to match up.  Once I got it on and around the fan, I tried to fit, my generator, and too tight.  Old belt must have been way stretched.  Worked that one out and pulled it out without cutting it.  went to the store on Sunday as Napa was closed and matched up to a new belt 1" bigger.  After comparing them, I thought 1" might not be enough so I got the next one up, so 2" bigger then the old.  Got that one on and to no suprise, too big.  Pulled that one out, and took it back and got the one inbetween.  Hope to put that one on tonight and get the generator on and start it up again.   Well, even a bad day tinkering on AC tractors is better then a good day at work.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2010 at 7:21pm
Chuck, I'm sitting here laughing as I read your post - sounds like something that would happen here in my shop! But you are totally right about the last part.
WC, CA, D14, WD45
DREAM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DREAM Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2010 at 7:36pm
Good luck Chuck. I hope it's going better for you than the hydraulic pump repairs to my C.
C Tucker, that was a cool video, but the one where the royal marines changed the engine in a Ford escort in 42 seconds was really neat! The guys that set the guiness record for fastest engine replacement on a VW bug at 1 min. 4 seconds was pretty good too.
This page was generated in 0.104 seconds.
