push pump
Ronnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ronnie Quote  Post ReplyReply Direct Link To This Post Topic: push pump
    Posted: 27 Mar 2014 at 7:51pm
Can any one tell me if a push pump will help my stock 7060 at the pulls we farm with the tractor and the injection pump is turned up all the way and it just seems it needs more fuel
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2014 at 9:41pm
Probably not, unless you have a blockage problem of some sort. I've run DM-4 Roosa pumps like that at approx. 325 HP for pulling and never had a pusher pump of any kind. It won't hurt but, it may not (probably not) make any difference.
Big Orange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Orange Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2014 at 11:31pm
Their is a lot more to turning a DM4 pump up, than screwing the leaf screws down, the roller shoes, need to shorter for 1 thing. Your pump probably has a delivery valve stop leaking. That will leak the fuel back in the pump that should be going to the injectors. Take it off & let a pump shop help you out.  GOOD LUCK
ACFarmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACFarmer Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2014 at 3:00pm
We run one on our 7050. Back when it was about new and it was pulling 6 bottoms every fall, grandpa said that it did help it out some.
Making a living farming with and working on Allis Equipment
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2014 at 5:15pm
Big Orange can you explain more on the delivery valve leaking? Ive got a 180 that seems the fuel bleeds back and takes forever to get it started/smokeing, what needs replacing?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ronnie Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2014 at 8:31pm
So if a delivery valve is bleading off it will be hard to start right? My 7060 is not hart to start
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2014 at 8:41pm
Im just guessing here ; but seems a delivery valve would leak back keeping the fuel to deliver to the injectors as fast
Edited by DougG - 02 Apr 2014 at 8:42pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ronnie Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2014 at 8:47pm
That's what I would but there talking bout it bleading off and I would think stuck ones would be hard to start or many no start
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2014 at 7:39am
A leaking delivery valve stop is an internal leak. It isn't that they lose prime with it leaking, it just doesn't deliver the required fuel. The delivery valve stop is basically the "cap" at the end of the high pressure passage in the rotor. A pump can be turned up slightly with a little know how, but it takes a lot of know how, and a complete teardown to really crank one up.
This page was generated in 0.309 seconds.
