Allis Chalmers WD/45
Forgiven09 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Forgiven09 Quote  Post ReplyReply Direct Link To This Post Topic: Allis Chalmers WD/45
    Posted: 26 Feb 2010 at 10:23pm
Hello let me say first of all I'm new here. I was wondering what is the difference between a Allis Chalmers WD and WD45. This may be a stupid ? but I want to be sure what I have. Thanks
Austin(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Austin(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2010 at 10:30pm
Well...more than likely your going to get someone on here that thinks they are funny and say the "45" ...so I will just get that over with right away.
"Better By Design"
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2010 at 10:35pm
Basically, A WD has a smaller engine and a large plate bolted to the right side of the engine. It can have a straight shift lever, however late models had a curved shifter.
ALLIS EXPRESS!
This year:
Randy(Mo) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Randy(Mo) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2010 at 10:35pm
A WD is 35hp and a WD45 is 45hp, A WD45 motor will have a serial number on the block that starts with 45-XXXX. A WD motor has a bolt on plate on the right side if I remember right. WD transmission will have a straight shift lever (except a 53 model) WD45 will have a curved shift lever. Also the only stupid question is the one that is never asked. Hope that helps
Joe(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2010 at 10:37pm
WD-45s had distributor ignition, a different transmission with a curved gear shift and helical cut gears, these changes occurred on late production WDs as well.  The most important difference is a 226 cubic inch engine.  The engine has no lifter cover, like a WD or WC engine dose.  They are also called power crater engines, because the combustion chamber is on built into the top of the piston.  I hope this helps.
Life is simpler when you plow around the stump.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Forgiven09 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2010 at 10:44pm
Thanks everyone good info!! So let me throw this one out there I have a chance to buy a WD or WD45 not sure yet going to look at it tomorrow. I do know however that it's a one owner and things as they should. It has like new tires, pto, three point hookup/not converted. It needs to be painted. What would be a fare price for this.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2010 at 10:47pm
$1200 for a WD, up to $1800 for a WD45.  They never came with a factory 3pt.....
ALLIS EXPRESS!
This year:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Forgiven09 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2010 at 10:49pm
The three point is reversed of what you need for modern implements. Correct?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2010 at 10:54pm
AC developed their own hitch system called the "snap coupler"  which is a very good system combined with their "traction booster" which transferred weight to the tractor. When the 3pt patents ran out, they were pretty much forced to change to the 3pt arrangement on later model tractors.  Their are AC and aftermarket 3pt conversion kits available. You need these conversions to use 3pt implements.
ALLIS EXPRESS!
This year:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2010 at 10:54pm
The "three point" as you call it is called Snap Coupler.  With implements made for it it is the best mounted implement hook up there is.  What all do plan to use the tractor for?  Most 3 point equipment can be adapted to snap coupler.  The snap coupler is a unique to Allis system.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2010 at 10:55pm
Seems Im just a little late with my responses.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Randy(Mo) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2010 at 10:57pm
Is it wide front, narrow front, power steering or not, the only factory 3point Allis ever had was an Oxnard 3point that you could order with the tractor or the aftermarket you get nowadays. P/S will add $500 to the price, wide front will add $400 to $500 to the price. The factory wide front is a square tube, not round
Post Options Post Options   Thanks (0) Thanks(0)   Quote Forgiven09 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2010 at 10:58pm
I plan on using a box blade/grader, and a bushog.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2010 at 11:09pm
Well you can get an AC blade for your grader needs, if you can find it you could get a snap coupler bushhog, or convert one to snap coupler.  Worst case scenario is use a pull type bushhog.  Good luck!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Forgiven09 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2010 at 11:15pm
Thanks for your help Joe.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2010 at 3:53am
The serial number is the real determining factor. 146606 is the last WD. 146607 is the first WD45. It's stamped into the left rear side of the rear axle housing. Might have to scrape off some paint to find it. New tires is a big plus. I spent $450 ea for rear tires for my D17.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2010 at 6:34am
Man, Brian is right there on the tires! Tires are a big plus on tractors because of the big hit in the wallet! Best way to ID the machine is the serial number. Coarse the side lifter plate is usually a dead give-away on a straight WD. Don't always go by the Mag or Distributor senerio either. It could have been changed sometime in its lifetime from Mag to Distributor if its a WD. Either way, you probably can't go wrong which ever model it is......
Steve@B&B
Post Options Post Options   Thanks (0) Thanks(0)   Quote Forgiven09 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2010 at 9:02am
Thanks, Brian and Steve good useful information.
Dave (NE) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2010 at 10:40am
Randy, is the oxnard 3-pt you refer to the snap coupler to three point adaptor or an actual 6-pt on the tractor without removing the drawbar?  Thanks, Dave
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2010 at 2:06pm
Randy Mo You might want to qualify your statement,( the only factory 3point Allis ever had was an Oxnard 3point that you could order with the tractor or the aftermarket you get nowadays.) to tractors prior to the late D series.
ToddSin NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ToddSin NY Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2010 at 7:02pm
Serail # is realy the only way to tell. As Steve has said alot of changes are made over the years to these tractors. My dads WD has a curved shifter which I think is factory. The shifters are very easy to change over and many have been changed to the curved shifter. The WD block will have a plate about 18" high and the length of the block on the right side, WD45 will not. Again did somebody swap out the motor?
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2010 at 8:05pm
Our '53 WD came new with battery ignition.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Randy(Mo) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2010 at 9:04pm
You are right CtuckerNWIL that was the only one prior to the D series Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote Forgiven09 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2010 at 9:13pm
My WD has the factory square wide front end.
