CA questions???
Larry in OK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry in OK Quote  Post ReplyReply Direct Link To This Post Topic: CA questions???
    Posted: 26 Feb 2010 at 3:45pm
Making a little progress on my '52 CA.
It runs and drives but I haven't ran it for maybe 30 minutes total yet, got to get a muffler dang that thing is loud with a straight pipe.
Got a couple of questions, the wire harnes is completeley shot. Not really a big deal and nothing I can't make mysell since I'm not doing a correct restoration.
What gauge is the heavy wire coming off the generator? Doesn't look big enough to be 8 but looks bigger than 10.
Also any major negatives to using a power washer on this thing? 50+ years of crud buildup is a serious mess. What I can see so far looks like pretty decent paint under the grease though.
Thanks
Gary in da UP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2010 at 4:14pm
If you have a concern about a wire size its always more better to error on the heavy side. I am a major proponent of over building.  And yea, give it a bath , at least you can get a wrench on it, there will be more opportunities to get greasy before your done. And I assume your changing all the fluids anyway.  Gary
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2010 at 5:29pm
I wrap a plastic bag around the distributor and tie it to keep water out.
Gary
Dave(inMA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2010 at 8:13pm
Go for it - I'd use something like Simple Green in the washer to give yourself a shot at cutting the baked on grease and dirt. Always amazes me how hard it is to get that stuff off!
WC, CA, D14, WD45
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2010 at 4:05am
I'm told oven cleaner does a good job softening the crud and then power washing it off. Might want to be sure to wear goggles when you wash it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2010 at 6:22am
As far as the pressure washing is concerned, as Dave said "Go for it". The ole' girl needs a good bath. The only thing good about the crust and grease is that rust doesn't start where all the grease is.  lol!  As far as the wiring is concerned, if your staying with the 6V system, your main leads to the Gennie, Ammeter, etc will be #10. Sub circuitry for lights, and Ignition 14 gauge works just fine. Make sure your 3 position switch is grounded, and all grounding connections clean and rust and crud free. You should be good to go.
Steve@B&B
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2010 at 7:37am
Oven cleaner does work. Comes in aerosol can, spray on let  soak in and work for a while rinse and scrub with wet brush. I did a whole tractor that way, one piece at a time.
Dusty
GregLawlerMinn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2010 at 7:51am
If you don't like the smell and/or chemical nature of oven cleaner, you may want to use the high pressure nozzle initially to break thru the crud (and blast some off). Then pour some of your favorite comcentrated degreaser (simple-green, purple-power, etc) in a spray bottle (I use empty windex or bath tub tile spray bottles) and spray down the tractor and let set for 5-10 minutes (apply more deagreaser to areas as needed) and hi-pressure wash again. Repeat the degreaser, soak spray cycle a few times and the paint that remains will be clean and free of oil/grease
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry in OK Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2010 at 8:22pm
Thanks for the tips guys.
Brother in law is bringing the power washer out tomorrow, I hosed it down with engine degreaser and will let it sit over night. I'll post up another pic after she gets her bath. The paint under the grease that I can see so far looks good.
Picked up some wire today and my order from OKTractor should be here early next week. If the generator works I'll be well on my way.
DREAM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DREAM Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2010 at 8:54pm
Sounds like you're making good progress. My son and I have a 3,000 PSI pressure washer that we bought reconditioned from Home Depot. It came with a rotary tip. That thing is awesome! The tip somehow oscillates as it sprays. It's like a zero degree tip, but it rotates in little circles. Hard to explain, but it makes a faster job of washing stuff down because it covers more area than a zero degree tip. Just make sure you have enough pressure and flow for it. Works very well for removing caked and baked on grease and even old paint.
Darrell Roberts View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Darrell Roberts Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2010 at 8:54am
I've done 2 tractors that way using oven cleaner and a high pressure washer. Works great but be sure to use eye protection with the oven cleaner. It even took off some of the loose paint. As for your wiring issue you might try your closest AGCO dealer. I was able to get a complete new harness for mine. If not and you want a very good wiring harness that's 100 % correct Steve in NJ is your man. Can personally reccomend his work. Thanks, Darrell
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry in OK Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2010 at 7:59pm
Well, she cleaned up pretty good. Took a couple hours with the pressure washer but she looks a bunch better.
No paint to speak of on the engine
Rear end before
After
Only real ugliness I found was a broken mounting hole on the exhaust manifold, the "fix" works so I'll leave it for now.
Edited by Larry in OK - 28 Feb 2010 at 8:01pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2010 at 8:15pm
Looks pretty good, Larry! Makes for a nicer machine to work on. Sounds like you had a good system.
WC, CA, D14, WD45
caRon View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote caRon Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2010 at 8:33pm
It cleaned up real nice, Larry. When I got my ca I sprayed it off at the car wash, but it didn't clean up that good. Did you try using the oven cleaner?
Dave King View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave King Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2010 at 8:46pm
Looking good. I especially like the temporary spare on the front.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry in OK Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2010 at 9:07pm
I'm thinking about getting another to match, the wheel on the other side is more square than round and the tire is showing cord in the side wall ion the inside.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave King Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2010 at 9:21pm
It's gotta be a lot cheaper than the correct one, and I doubt you'll exceed the 50mph limit on the tire.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DREAM Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2010 at 9:31pm
Looks good Larry. I need to get the pressure washer to mine. It's not really greasy, just dirty. Of course, now that I run it from time to time, oil leaks are developing from the dried out gaskets. I'm afraid to get the washer out. Last time I washed down a trailer I was repainting, my wife said "next time you have that thing out, we need to wash down the house". It may be a while before the C gets a proper bath.LOL!
This page was generated in 0.073 seconds.
