Painting underside of deck
Larry(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry(OH) Quote  Post ReplyReply Direct Link To This Post Topic: Painting underside of deck
    Posted: 24 Mar 2014 at 5:24am
What do you guys use for paint on the bottom of the decks?  I recently blasted my deck and want to put something on the bottom that stays.  I figured I would use an oil based primer, then paint.  Was told to paint, then wait a week then cover it with slip plate.  Also told by an old guy to paint the underside with Meyers snow plow paint as it is real durable.  Mow about 2 acres a week with it.  60" deck
Thanks, LH
'40 WC puller, '65 770 Ollie
*ALLIS EXPRESS contact*
I can explain it to you, BUT I cannot understand it for you!!
Rob Rolando View Drop Down
Suspended User -
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rob Rolando Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2014 at 3:33pm
Glyptal.
We use this inside are racing engines.
You can get it from Eastwood.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2014 at 6:27am
I wonder if 'rhinoliner' or whatever it's called would be good to use. The stuff they coat pickup beds with, sometimes the frames,wheelwells,etc.
jay
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2014 at 11:30am
Glyptal - is used as electrical insulation material for painting winding in motors to prevent electrical shorts - also used to seal pipe joints and such - good properties . but unsure of slipperiness. Might work fine.
Mike-IA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike-IA Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2014 at 7:30pm
Have it powder coated. Seams to be pretty durable.
ctbowles58 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ctbowles58 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2014 at 8:09pm
there is a spray-on "TEFLON" coating that works great,but you need to clean and re-coat it every year. i bought a new mower once and the dealer coated the bottom of the deck with it for me, but i cant remember what its called.
190XT 2WD45 WF D15 D14 CA BIG10 302 & 303 bailers 77G rake 80R mower 6 plows and alot more
Suspended User -
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rob Rolando Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2014 at 6:11pm
Right, I hauled it for GE years ago before they sold it off to another company.
This stuff can go right on clean bare metal and it doesn't come off. A lot of racing engine builders coat the inside of engines with it to keep oil from sticking to the rough cast iron.
Makes a nice smooth surface almost like a plastic coating.
Edited by Rob Rolando - 07 Apr 2014 at 6:18pm
This page was generated in 0.266 seconds.
