D19 engine swap
Stu ECWI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stu ECWI Quote  Post ReplyReply Direct Link To This Post Topic: D19 engine swap
    Posted: 26 Feb 2010 at 3:43pm
Gentlemen,
Went with a friend to look at a C2 combine engine this afternoon.  He plans on putting it in his D19.  Are there any major changes to the combine engine that are needed to put it in the tractor?  It looks like a very straight forward swap from what we can see, but I know someone here knows if there's something we didn't consider.  Thanks,  Stu
skipwelte View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skipwelte Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2010 at 4:07pm
Im thinkin the front eng plate, the rear eng plate and flywheel, the govenor assy , carburator  and I cant remember but maybe the water pump and crankpulley.  You didnt say, I assume they are both gas engines.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stu ECWI Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2010 at 5:08pm
They are both gas.
Thanks Skip, I knew the pullies and water pump looked different.  I hadn't thought of the flywheel.
