653 dozer forsale |
PJsomd
Joined: 17 Jan 2010 Location: Southern MD Points: 43 |
Topic: 653 dozer forsalePosted: 22 Mar 2014 at 8:02pm |
Just Fyi I seen this on craigslist eastern shore of Maryland for anyone interested.Not mine http://easternshore.craigslist.org/grd/4363368573.html
JC-WI
Joined: 11 Sep 2009 Location: wisconsin Points: 34623 |
Posted: 22 Mar 2014 at 8:17pm |
Why are all the good ones so far away?
says one track jumps... probably needs new p&B and sprocket... $4500 or bo.
Heres a live link to it.
The truth is the truth, sugar coated or not. Trawler II says, "Remember that." |
darrel in ND
Joined: 22 Nov 2009 Location: Hebron, ND Points: 8779 |
Posted: 22 Mar 2014 at 9:54pm |
I'd like to have that lil devil. Darrel
JC-WI
Posted: 22 Mar 2014 at 10:04pm |
Theres probably more that would like it too... LOL
JohnCO
Joined: 11 Sep 2009 Location: Niwot Colo Points: 8992 |
Posted: 23 Mar 2014 at 11:44pm |
I'd love to have it too but over 2000 miles away.
Allis Express participant |
JC-WI
Posted: 24 Mar 2014 at 12:43am |
Seems those that would like to have it keep getting further and further away. LOL
Here's a pic of it just to temp and tease others...
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42269 |
Posted: 25 Mar 2014 at 11:11pm |
after having a HD4 loader, and running out of hands with all the levers it would be nice to have a pedal steer machine .
Then moving from a HD5 to a FD5 with the power-shift make things easy . Almost no cat skinning knowledge needed , well except to run the blade . Would almost be like going from HD4 to the 653 if it has the decelerator also.
WayneB
Joined: 15 Jun 2013 Location: Lunenburg. VA Points: 15 |
Posted: 26 Mar 2014 at 10:29am |
Needs right FD Pinion/Bull gear and other assundry parts to install. From what is learn, about $1500 in parts. Talked to the guy. Its been advertized for a while. Wayne |
Coke-in-MN
Posted: 26 Mar 2014 at 11:42am |
That is one of the weak spots on these machines - with single reduction case and small bearings holding these components - I replaced one pinion , one bull gear and 3 axles on my HD4 , also had to have both cases machined for new bearing cup for axle, area as the case is not real strong and the area will crack or distort as bearings wear or turn in case.
