HD16 reverse rippers |
UMFINC
Joined: 16 Mar 2010 Location: anaheim ca. Points: 7 |
Topic: HD16 reverse rippersPosted: 22 Mar 2014 at 1:23am |
hello I'm new on this site this is all new to me . I purchased an HD 16m m for military. I am looking for reversing rippers for my machine Really need some because has no rippers at all ? if anybody has any to sell or has one of the reversing ripper shanks maybe they can send me some dimensions or a drawn out layout on a cardboard I'll pay shipping. I have all the books for this machine shop manuals parts manual maint manual original from factory so if anyone out there needs any info let me now . I'm going to change motor oil for first time since I've owned it is 15/40weight ok for this 16000 turbo engine. I also use Lucas in all my engines. Will this help or harm an older engine. Thanks for any input
Edited by UMFINC - 22 Mar 2014 at 1:49am |
James Coons
Posted: 23 Mar 2014 at 12:21am |
I have been searching for the same ripper shanks for quite some time with no luck. Find plenty of military machines but the shanks are always missing. I'm working with a cutting edge manufacturer to see about getting some made up.
steve(ill)
Joined: 11 Sep 2009 Location: illinois Points: 90948 |
Posted: 24 Mar 2014 at 7:17pm |
Toward the end of the manufacturing on large crawlers, we put 15-40 in the motors. Several of the coal mines around the country put the same oil in steering and transmissions to standardize on oil. 15-40 works great in most diesels.
Deas Plant.
Posted: 25 Mar 2014 at 8:12am |
Hi, UMFINC.
You may find that pin-retained ripper shanks from a grader ripper (NOT the 'scarifier' shanks) or a small to medium track loader ripper - even a Cat D4-sized, or thereabouts, dozer - would do what you want if you weld brackets to the back of the blade to allow them to trail when you are pushing forward and swing down to rip as you reverse. If my (aging) memory serves me rightly, with most of the reversing rippers, you had to lift the blade a little to allow the shanks to swing down, then lower it as you reversed to get them to penetrate. Just my 0.02. Hope it helps. You have a wonderful ripping time. Best wishes. Deas Plant. |
