D15 Hi crop
BrianC,Ont View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC,Ont Quote  Post ReplyReply Direct Link To This Post Topic: D15 Hi crop
    Posted: 25 Feb 2010 at 5:35pm
I have a set of 12.4x38 rear wheels and tires for the D15. Can I put a D17 narrow front under it to raise the front up, or is there a hi crop version of the narrow front. Also maybe I would convert it back to wide front if I could locate the taller front spindles. Is there anything else that needs to be changed to make it a hi crop.
mark/indiana View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mark/indiana Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2010 at 5:44pm
What I did was get an extra tall set of front tires...I already had the heavy duty rims...
(9.50)
My first choice was to put 20" wheels on the front like a 180HC..but this was easier and I found the tires...
Have cultiated and sprayed everything this way for 3 years with no problems...
Let me know if you need more info..Mark
mark/indiana..."My favorite Allis Tractor or Crawler is the one I'm sitting on at the time!!..
Post Options Post Options   Thanks (0) Thanks(0)   Quote AMB(wcIL) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2010 at 6:10pm
We have a D15 SER II HI-crop, the rear axle has a 6" extention in it,plus the fender brackets are diffrent from a row-crop. I believe the front spendle is 5" taller than a row-crop.      Andy
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC,Ont Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2010 at 1:16pm
Will the D17 narrow front bolt up to the D15. I think it is taller.
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2010 at 6:15pm
Brian; I think the the narrow front for the D-14,15,17 are the same height. The D-19 is taller. I have a spoke type 16" single front wheel assembly that not for sale. Planning on puting on the D-17IV with the 38" rears.
