Rebuild kit?
Tractor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tractor Quote  Post ReplyReply Direct Link To This Post Topic: Rebuild kit?
    Posted: 10 Mar 2014 at 7:38pm
i'm new to the forum and my brother and i are restoring an allis chalmers b-12 and i was wondering if there was anywhere to get a rebuild kit for the a briggs and straton 12 hp engine?
Edited by Tractor - 11 Mar 2014 at 10:07am
Clay T. Souerdike View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clay T. Souerdike Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2014 at 11:05am
http://www.ebay.com/bhp/briggs-stratton-engine-rebuild
 when in doubt turn to ebay? I thnk I saw a 12 hp one on that list.
“You are not entitled to your opinion. You are entitled to your informed opinion. No one is entitled to be ignorant.” - Harlan Ellison
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tractor Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2014 at 6:46am
Ok thanks
Steve Kauffman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve Kauffman Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2014 at 4:17pm
Hey foxes about time you get on this forum
Steve
ctbowles58 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ctbowles58 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2014 at 10:14pm
napa, can get them.
190XT 2WD45 WF D15 D14 CA BIG10 302 & 303 bailers 77G rake 80R mower 6 plows and alot more
ACmowerguy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACmowerguy Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2014 at 10:29pm
The original B-12 engine is a model 300421 ? or something close. Briggs has discontinued the oversized pistons for that engine and I don't believe Rotary or any other manufacturers make replacement pistons. Rods can be had through Rotary or Primeline. Over on the SimpleTractors forum several members have bored their 12hp blocks out to the standard bore for a 32 cubic inch Briggs (14hp to 16hp). The 12hp CI engine has the same external dimensions and the block is the same thickness as the 14-16hp CI Briggs engines. The pistons STD, .010, and .020 are readily available for these engines and it will give you more power. You might need to change to a 14hp CYL head but it is a direct bolt-on replacement.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tractor Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2014 at 5:18pm
does anybody know where to find the model number on the engine? i've been looking but i can't find it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACmowerguy Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2014 at 6:17pm
It should be on the blower cover, just to the right hand side of the carburetor.
