Help with a WD45 factory power steering pump
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Topic: Help with a WD45 factory power steering pump
    Posted: 10 Mar 2014 at 7:19pm
Not a happy camper as I discovered the shaft seal is leaking on my power steering pump. Instructions say to take apart the pump so the shaft can be removed along with the seal. Trouble is the pump is screwed together with what looks like 8, 12 point cap screws. Will standard 12 point sockets fit these? All I have is 6 point and a 1/4" is too small and a 9/32" is too big.
Here's a picture of the 8 screws and then one of the leaking shaft seal.
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
Josh Day View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Josh Day Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2014 at 7:22pm
Metric maybe
Edited by Josh Day - 10 Mar 2014 at 7:23pm
AC's 75' 7040, 64' D-17S4, 55'WD-45, 54' WD-45, 53' WD-45, 53' WD, 52' CA, 36' WC. IH 656. Deere's 38' A, and 47' A
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2014 at 7:26pm
Metric on a WD-45?????????????? GET A 12 POINT SOCKET...PROBABLY 1/4" 12 POINT.
den/southern illinoi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote den/southern illinoi Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2014 at 7:36pm
Had the same problem...McMaster Carr has the 12 point sockets in stock and are quick on delivery.  As I recall however, you want to get a deep well socket because the normal one is too thick to fit in the recessed area.  Den
Own 4 wheel 20, 2-5015, 5020 and associated equipment and 2 electric forklifts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2014 at 7:52pm
Sears has em (Craftsman)
Edited by SteveM C/IL - 10 Mar 2014 at 7:52pm
Ryan Renko View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ryan Renko Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2014 at 8:05pm
Keep us updated on the progress with the John Barnes pump. I have one on my Series IV and I was talking shop with the local hydraulic/pump repair shop and he said those are a b*tch to work on. Ryan
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2014 at 8:34pm
Thanks everyone. You know what they say "every project is an opportunity to acquire more tools" I'll update as soon as I get the sockets.
1968 one-seventy
1956 F40 Ferguson
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2014 at 9:25pm
Should be a 1/4" 12-point deep-well, and yes, a good investment.
It's been my experience that specialty shop guys will, more often than not, advise against working on them yourself, particularly even if the job isn't difficult.
I recently had a similar problem with the steering control valve on my Hyster H50H forklift.... it started gushing fluid on my left shoe.
Some steering valves and hydraulic pumps can be somewhat 'party' conglomeration of stuff, and of course, they're sensitive to dirt, grit, and choices of solvents, so when you dismantle it, hold it IN a bucket (so anything that comes out unexpectedly, lands where you can find it) and don't be afraid to take pictures in the process, so you have reference for reassembly.
ON my steering valve, once dismantled, knocking out the seals and installing new was easy. Assembling it required a little vaseline (to help hold the vanes and springs 'n stuff in place) for reassembly... but once done, torque it right, put it back together, and it hasn't leaked a drop since.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2014 at 2:06am
Thanks Dave. I found a set on Amazon and they will be here in a couple of days. Guess I can spend that time polishing out the paint on the hood. Still have a little haze in it. Thanks for all the tips!!
1968 one-seventy
1956 F40 Ferguson
JayIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JayIN Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2014 at 3:20am
There is a little bit of haze in everything I do.all day long.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2014 at 7:51pm
Well the 12 point sockets came today. Got the pump apart and the seal replaced and have it back together. There was a gasket between the two pieces of the pump. It looked like a metal foil gasket. For some strange reason I was able to get it apart, get the old seal out and new one in and it back together and didn't destroy the foil gasket. I'll put it back on the WD45 tomorrow night and then get it tested over the weekend. Thanks for all the help and suggestions everyone. Here's a few pictures.
1968 one-seventy
1956 F40 Ferguson
Toolsnob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Toolsnob Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2017 at 2:15pm
What size pulley was on the front of your pump? The shaft fell out of mine sometime before I aquired it so I had to make a new shaft but I don't know what size pulley it is supposed to have.
