fuel
allispuller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allispuller Quote  Post ReplyReply Direct Link To This Post Topic: fuel
    Posted: 06 Mar 2014 at 11:08pm
Was wondering what kind of fuel you guys with higher compression motors were running and what you have experienced. I have a WD45 with higher compression and thought about changing fuel.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2014 at 5:57am
Until you get over 8 to 1 compression (170-180 psi cranking compression) you don't need anything better than 87 octane. Now, how high are you ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote allispuller Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2014 at 6:24am
10.5 to 1
cotncrzy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cotncrzy Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2014 at 6:48am
  VP fuels are very consistant. I run CHP, its oxygenated, and 107 octane. My compression ratio is close to that.
C, WD45,WD puller, 185, 200, 7060 Red Belly, 7060 Black Belly,8010, and a R52 Gleaner, AND PROUD OF THEM!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2014 at 6:51am
And at that ratio (240 psi??), your ignition timing will need to be around 18 to 20 degrees BTDC and not 30 degrees as marked on the flywheel.
mattb View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mattb Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2014 at 7:18am
I run e85 and pump gas mixed
Post Options Post Options   Thanks (0) Thanks(0)   Quote allispuller Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2014 at 1:12pm
I have checked into ignite 108 it is an ethanol based fuel. I was told it is 90% ethanol. I wasnt really sure about an ethanol because i know ethanol can be real hard on seals and other carb components. I was also told but you can create more power on ethanol but i wasnt sure about that because i dont know alot about ethanol.
patrickmull View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote patrickmull Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2014 at 4:41pm
I run 100 aviation gas
Post Options Post Options   Thanks (0) Thanks(0)   Quote allispuller Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2014 at 5:53pm
cotncrzy what are you paying for you VP CHP
Post Options Post Options   Thanks (0) Thanks(0)   Quote allispuller Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2014 at 7:11pm
Another question how much would an oxygenated fuel help
Post Options Post Options   Thanks (0) Thanks(0)   Quote cotncrzy Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2014 at 10:48am
14 dollars per gallon. It seems to help tremendously in these
engines that dont take in air well
Post Options Post Options   Thanks (0) Thanks(0)   Quote allispuller Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2014 at 10:58am
thanks i will check into it. i will probably end up going that route. like i said i checked into ethanol but im just not sold on it in this type of application
Post Options Post Options   Thanks (0) Thanks(0)   Quote cotncrzy Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2014 at 12:13pm
You will like the CHP except for the price, LOL. someone suggested av gas, it should work but we was having detionation problems with it. You have to drain the carb with the CHP fuel.
Post Options Post Options   Thanks (0) Thanks(0)   Quote allispuller Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2014 at 12:35pm
i had been running turbo blue but was kinda inconsistant and never knew if i could get it from the local dealer
Post Options Post Options   Thanks (0) Thanks(0)   Quote allispuller Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2014 at 2:46pm
what did you have to change to run the oxygenated fuel
Post Options Post Options   Thanks (0) Thanks(0)   Quote cotncrzy Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2014 at 4:15pm
It takes more fuel to maintain a good fuel air mixture.. on the old carb we bored the load jet some to get it rich at idle and still see a tad bit of smoke under full load.
Post Options Post Options   Thanks (0) Thanks(0)   Quote allispuller Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2014 at 4:17pm
ok ive got a modified carb so i should be close hopefully
Post Options Post Options   Thanks (0) Thanks(0)   Quote cotncrzy Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2014 at 4:17pm
wi50 set me up a carb that worked perfect. Just opened the load screw... we did this when we increased cid.
Post Options Post Options   Thanks (0) Thanks(0)   Quote allispuller Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2014 at 5:02pm
thanks for all your help i appreciate it i will check into the chp
