D14 Won't Idle Down
Mike(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike(GA) Quote  Post ReplyReply Direct Link To This Post Topic: D14 Won't Idle Down
    Posted: 04 Mar 2014 at 11:32am
Were do I start looking?  Have not had time to look.  Just rebuilt the carburator.  Used it
Saturday.  When putting the tractor up it would not idle down.  Moved the throtle lever up and it did not slow down immeditatley.  Took several attempts and then manually moved the carb to get it to slow down.  (Not a mechanic, just a parts changer)
Edited by Mike(GA) - 04 Mar 2014 at 11:36am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2014 at 11:34am
Wrong forum will try to move.
Seth Souerdike View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Seth Souerdike Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2014 at 11:47am
wrong forum but still, sounds like you need to get inside her and have a look, might be a broken rod down there. or are the idle pins way off?
There are no atheist in foxholes.
TOMIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TOMIA Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2014 at 5:12pm
Sounds to me like your linkage might be binding or rubbing somewhere so that it won't idle down.
This page was generated in 0.311 seconds.
