WD spindle shaft bearing ??
Gary in da UP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Topic: WD spindle shaft bearing ??
    Posted: 24 Feb 2010 at 1:47pm
 Would anyone be able to provide the Timkin # for the bearing and race for the WD spindle shaft lower bearing?  Thanks, Gary
j.w.freck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote j.w.freck Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2010 at 8:09pm
if you have the old bearing out,and there is a bearing supply store near you,take it to them and they will get you flying again...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2010 at 7:34am
 The cone on my bearing is ground away from 65 years of neglect , the race is a link belt #33454x. I don't think a replacement bearing will have rollers that are fatter at the ends and a race that is convex. The closest bearing supply is 150+ miles away ,unless I were to cross over into Canada, and that is a big hassle for a bearing. Living in the UP has its  disadvantages. If no one here can help the I'll fork  my $$$ to AGCO.  Thanks, Gary
