Off The Farm tractor pull
Juiceman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Juiceman Quote  Post ReplyReply Direct Link To This Post Topic: Off The Farm tractor pull
    Posted: 28 Feb 2014 at 11:25pm
There will be an off the farm tractor pull at the West Virginia State farm museum May 3 at 1pm. 4000 to 9000lbs at 500lb increments. Any age of tractor as long as it is two wheel drive and no alterations to the tires. No turbos or shifting going down the track. Stock hitch assembly, 20 inch maximum. We will provide same clevis for everyone. This pull is a no pay back pull, proceeds going towards upkeep, and this season's remaining pulls. 10 dollars for the first hook in each class, 5 dollars for the second. Maximum of two hooks per class. Distances will be kept, so you can tell how you stacked up, and for bragging rights. Lol 3.5 mph speed limit. 3 strikes and you are out. This is the second year trying this type of pull to kick the year off. Just for fun. There will also a test and tune for the regular antique guys. The farm tractors pull first in each class, then the antiques, and so on. If your not to far away, and want to come, pm me and ill give you all the info you need.
Edited by Juiceman - 28 Feb 2014 at 11:37pm
