Cab roof for 7050
7060 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 7060 Quote  Post ReplyReply Direct Link To This Post Topic: Cab roof for 7050
    Posted: 23 Feb 2010 at 12:03pm
 Does anyone know where I could find a cab roof for a 7050? Could be new or used. Metal or plastic. thanks
skipwetle NWIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skipwetle NWIA Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2010 at 12:38pm
The plastic ones had the front turn signals in the roof, the steel ones have the front turn signals on the cab.  Your 7050 should have a plastic one, youll have to move the front turn lites to the front of the cab if you get  a steel roof.  Drill new holes to mount the lites with one large hole for the wire to go thru, no one can tell the difference.  the salvage yards is usually where you can find one.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2010 at 12:39pm
Cook Tractor in Clinton, MO will have probably 5-10 of the 7000 series in the salvage lot at any one time.  Mike
1968 Gleaner EIII w 10' & 330
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
1956 All-Crop 66 Big Bin
7060 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 7060 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2010 at 10:34pm
Mine does have the plastic roof, but after looking at my 7060 I thought I could either run them through the cab or maybe cut the holes in a metal roof. The roof I have now the drip ledge around it is broke off and its cracked up the corners and is getting worse. Ill give Cook's a call tomorrow and see. I know of a local tractor that was send down there for scrap because the powershift quit it. Wish I could have got ahold of it before it left. thanks
