WTB - Hyd front pump for HD6 |
ccpanel
Topic: WTB - Hyd front pump for HD6Posted: 20 Feb 2014 at 5:38pm |
looking for front hyd pump for 1964 HD6 with allis engine. not budu or detroit.
according to dad it mounts to front pulley. send pics and price please. |
Dozer
Joined: 16 Aug 2011 Location: SW New York Points: 689 |
Posted: 22 Feb 2014 at 7:24am |
The HD6 has a Buda HD344 engine manufactured by Allis Chalmers
Allis Chalmers bought out Buda The HD5 has the Detroit 2-71 |
ccpanel
Posted: 22 Feb 2014 at 9:18pm |
ah-ha!
the guys at Arnolds in Colusa, CA(original allis dealer and yard FULL of orange allis....) told me the OEM pump that goes with hardnose is not available to them, and not realyl worth the hassle of installation. they suggested i just use my low pressure rear pump to run the dozer. i may or may not. first things first though-getting head rebuilt and engine fired up(for first time since 1988) |
http://oldironforsale.blogspot.com/
Dozer
Posted: 23 Feb 2014 at 8:30am |
If your HD6 had a live pto you could install a rear pump. I don't think HD6's with the pto option had live pto's. This means that in order to use your hydraulics you will need to do it while moving. You need a 30 gpm pump. An engine driven pump is more vercitile.
ccpanel
Posted: 23 Feb 2014 at 4:56pm |
hence the reason dad wants the front drive version.
our rear pump i think is only live in motion. |
DiyDave
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 55292 |
Posted: 23 Feb 2014 at 5:28pm |
Try Ebay? I think I saw a front mounted pump, for a dozer, on there a couple days ago.
ccpanel
Posted: 23 Feb 2014 at 7:24pm |
the front pump dad wants is specific to the AC in that it mounts to front pulley but stil clears hard nose.
he has a specific one in mind but I havnt been over to his place to look at his parts books. hes still in hospital rehab after heart attack. |
Andrew_D
Joined: 28 May 2013 Location: Newdale,MB,Can Points: 148 |
Posted: 23 Feb 2014 at 8:28pm |
Does it have to be the actual AC pump?? There was a thread on here not long ago looking for an aftermarket pump to put on an AC dozer.
Andrew Edit: Found the thread: http://www.allischalmers.com/forum/forum_posts.asp?TID=83219 Edited by Andrew_D - 23 Feb 2014 at 8:32pm |
dadsdozerhd5b
Joined: 27 Sep 2009 Location: lansdale pa. Points: 537 |
Posted: 25 Feb 2014 at 4:05pm |
is the pump the same as a hd5b? I have a few of those. I will get pics as soon as possible. it mounts in the front and is driven from the center of the crank pulley. let me know if this sounds like yours. not sure of gpm but it runs a hd5b just fine. I do not have a parts book for a hd6
ccpanel
Posted: 25 Feb 2014 at 6:47pm |
its highly likely.
dad says his motor is a allis not a buda. BUT.... i havnt got my hands on his parts book yet. is your motor a detroit? the one hes looking for is supposed to mount to front pulley. we dont have one to compare. next time I go out to farm(he comes home from rehab tomorrow) I will take pics of front pulley and look at parts book for numbers. thanks! |
dadsdozerhd5b
Posted: 25 Feb 2014 at 7:42pm |
all hd5's had detroits. they all drive off of the front of the crank in the center of the pulley. hd6's should be the same. I believe the 6's had a longer track frame and obviously bigger motor but the rear ends were the same. I will get or find pics for you soon.
HD6 Merv
Joined: 03 Aug 2010 Location: New Zealand Points: 501 |
Posted: 25 Feb 2014 at 11:27pm |
if its a HD6 with a 6000 motor, the pump is integral with the resivior and valve in the front. buda powered ones have same setup as HD5, just the pump is on the front, tank and valve are on rh fender
tits tyres and tracks
they all cost you money |
ccpanel
Posted: 26 Feb 2014 at 12:22am |
How do I find out what series engine it is?
ccpanel
Posted: 26 Feb 2014 at 9:49am |
and ours is for sure NOT a detroit.
ac_sd
Posted: 26 Feb 2014 at 10:53am |
I have a hydraulic pump off an early HD_6G with the 344 Engine. The mount would likely fit to the 6000 engine in your machine. You also might try John Parks at General Gear, He most likely would have one and He is very fair and good to deal with. His phone # is: 208-342-8911.
