Fluid In Tires
fixer1958 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fixer1958 Quote  Post ReplyReply Direct Link To This Post Topic: Fluid In Tires
    Posted: 22 Feb 2010 at 7:51pm
Is there any problem with using just antifreeze mixed 50/50?
If not a problem, how much do you put in?
Wanting it for a WD. Thinking about putting it in the front tires also.
I have an old backhoe 6' bucket I put a 3-point attachment on.
There is about #200 hanging on the front now but it's not enough when I load the bucket with rocks or green hedge.
I also haul a 250 gal water tank on bale forks. I can get 225 gals in it and get it 6" off the ground and the front tires about the same distance. Use it for watering hogs. Sucks to manuver. That's why I'm asking.
The reason for the rear tire fluid is because I am going to try to scrounge up a FEL for it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2010 at 7:54pm
I put -20 windshield washer fluid in the front tires on my D17.  That's lots cheaper than mixing engine anti-freeze with water 50/50 if you don't go the traditional calcium chloride route.  Here's a table you can use on approximate gallons for various tire sizes.  Mike
http://www.tractorsmart.com/Farm_Tractor_Liquid_Tire_Ballast.htm
1968 Gleaner EIII w 10' & 330
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
1956 All-Crop 66 Big Bin
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2010 at 7:57pm
One problem is that if it leaks out and your pets(cats/dogs) start licking it, they can die.
 Calcium is bad for rotting out rims(my D-14 #2 needs one,sigh..)
Fill with valve at 10 or 2 oclock position.
steffensen View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote steffensen Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2010 at 8:10pm
You could try Rim Guard. Supposed to be non-toxic and won't rot out rims.
Post Options Post Options   Thanks (0) Thanks(0)   Quote fixer1958 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2010 at 8:26pm
I was pondering washer fluid. It would be cheaper.
You are right about the toxic part of antifreeze, but there is supposed to be a bittering agent in it now. But then again, dogs think cat turds are tootsie rolls so it may not affect there taste buds.
I have one dog that will eat anything that won't eat her first so.........!
I have always thought our best defense would be to load up an ICBM with used cat litter
and drop a few on the 'unlikeables'. The wars would be over.
Thanks for the chart and the input.
Gives me a good idea where to start.
