Needing some Mexican Hat dual adapters; 190 xt
Orange Pulling View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Pulling Quote  Post ReplyReply Direct Link To This Post Topic: Needing some Mexican Hat dual adapters; 190 xt
    Posted: 22 Feb 2010 at 6:50pm
Anyone have dual adapters for a 190 xt; Ive heard them called the - Mexican Hat- style ; they bolt on the castings on the wheels ;
JP (nwOH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JP (nwOH) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2010 at 9:09pm
I have a set.  419-583-0703
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2010 at 12:28am
i have some....somewhere!!!!...hmmmmm
Dans 7080 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dans 7080 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2010 at 2:12am
how many bolts? 9 or 10? will they work on 34s or 38s? what kinda price?
Post Options Post Options   Thanks (0) Thanks(0)   Quote JP (nwOH) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2010 at 11:24am
9 bolt.   Bolt to the casting.  I believe they will work on the 34 or 38 casting.  I am sure some one correct me if I am wrong.  JP
BobHnwO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BobHnwO Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2010 at 3:33pm
I think the only difference in dual adapters is axle diameter.
Chad (MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chad (MN) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2010 at 3:45pm
As far as I know, AC made at least three different style of 9-bolt dual castings that fit the 34 or 38 in. wheels.  Some have diameter smaller studs (9/16 in.?) and the second type has larger (3/4 in.?) studs to bolt the duals on.   The third type uses the larger studs and has gussets cast onto the "ears" which bolt to the tractor's centers  because of higher horsepower of the D-21/210/220.  I have a set of adapters with the larger studs for sale.  Send me a PM if interested.
220 3-190XT 2-D19d D19g 5-D17 UC 3-WC 2-WD 3-WD45 CA C H3 7-AllCrops 14-plows 3-Gleaners Lawnmowers SC-equipment
BJ famfrm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BJ famfrm Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2010 at 8:52pm
I have a set of these dual hubs also west central Il BJ FAMFRM 309-945-5382
niel ev View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote niel ev Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2010 at 9:35am
We have a couple of pairs let me know if you need them 1 618 282 2477 Niel
ILGLEANER View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ILGLEANER Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2010 at 11:02am
What are these things worth? What are you guys asking for them?
                               Thanks,  IG
