Bareback CA
Ken in Texas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Topic: Bareback CA
    Posted: 15 Feb 2014 at 6:40pm
Here's a look at the back end of my CA
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2014 at 7:01pm
This was back in 08.  That is a C drawbar. I have modfied the hitch somewhat last season to shorten the drawbar hitch point closer to the 16 inch minimum distance to the centerline of the axle and raise it up to the max of 20 inches. The drawbar support is now a 3x3 angle used as a suitcase weight bracket.
Because the seat spring base is part of the PTO, I had to fabricate a base on a piece of 1 1/2 x 3 tube stock. The original solid tool bar is now just a piece of pipe.
Getting the power to the track is by way of 13-6 X 24 Firestones
dgerth View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dgerth Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2014 at 8:19am
Ken,
Good lookin CA! I'm tryin to build a CA puller and I have a ? for you, when removing the PTO/ hydraulic pump cover, what happens to the PTO shaft? Does it just come out or does one have to manufacture a housing to support it?
Also, What motor are you using, a 139 or 160cid  or have you built up the 125? don't want specifics unless your willing, just ideas.
tks,
Dan
PS, If you live in Henderson, Ive got Grandkids in Rusk.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2014 at 1:04pm
dgarth
    I'm running a bone stock 125 in 3500 & 4000  antique farm stock weighted class. Plenty power in first gear. Around here there is no competition in 2500 or 3000. I hate pulling against myself. I had no problem getting down to 2500 with my CA. To get to 3500 I'm running water in the rears with Farmall steel wheels and Farmall wheel weights plus engine side weights. So far I get away with calling it a Farm Stock Puller.
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2014 at 1:32pm
When you pull to PTO assembly from the tractor there is just a stub shaft sticking out. the Cover plate has a dimple about 2 inches in it for the stub. I think I still hacve a factory delete plate some where.
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2014 at 4:49am
Good job Ken.
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2014 at 5:51am
We have a plethora of Farmall C's in 3000 and 3500 around here. Hard to beat those suckers.
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote dgerth Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2014 at 7:11am
Ken,
I sent you a PM about the plate.
tks,
dg
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2014 at 9:57pm
Charlie-   There is a kid down here with a Super C his grandpa built for him that gives this old CA of mine fits in #3500 class. It is usually either me or him. What really makes me nuts is a chubby little gal on a JD M that knows just how to bounce her rear end to get that extra foot on both of us. lol
Post Options Post Options   Thanks (0) Thanks(0)   Quote dgerth Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2014 at 6:00am
Ken,
I thought that the "bouncing stuff" was not quite kosher. Youo'll sure enuff get "bounced"
If you do that up here.
dg
JoeO(CMO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(CMO) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2014 at 8:41pm
bump
This page was generated in 0.065 seconds.
