185 anti freeze
tractorman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tractorman Quote  Post ReplyReply Direct Link To This Post Topic: 185 anti freeze
    Posted: 22 Feb 2010 at 6:28pm
my allis 185 has been drinking some anti freeze, i pre heat it with a tank heater for anything from 1 to 4 hours before starting, then run about an hour to feed hay daily, located west central wisconsin.  seems like something in the range of a quart daily. any ideas, oil is black not milky, don't see any change  in color of exhaust, and can't see any leaks?
kip in cny View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kip in cny Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2010 at 6:57pm
get a pressure tester from napa and pump the system up to 12lbs and watch for leaks is  the easy way to find out whats going on
160 CA 920diesel 5020 HD-3
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2010 at 7:25pm
I had a 200 do that, always low on water ,the sleeves were pitting -electrolises- it would burn the water with the fuel , a little at first , 6 months later she started steaming bad out the blowby , but it would be best to get a pressure tester
This page was generated in 0.071 seconds.
