82S Mower Parts
Doug View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Doug Quote  Post ReplyReply Direct Link To This Post Topic: 82S Mower Parts
    Posted: 22 Feb 2010 at 5:45pm
I am repairing a 82S mower and need the following parts:
P/N 804502
P/N 804501
They are both Pittman bearings.
Does anyone know where I could get them other than from AGCO?
Thanks
Doug
Jack(Ky) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jack(Ky) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2010 at 5:48pm
If there is any kind of number on them or if you could send a picture with the dimensions I should be able to get them. I make my living at a parts dept in a machine shop and we can come up with about any bearing. JP
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2010 at 5:35pm
The Large bearing (#804501) is a fairly common bearing.  The last ones I bought from an auto parts store had a number SPE 6304.
The smaller bearing, on the other hand, is an uncommon bearing used in the small aircraft industry. It's common number is simply KP-8. Go to Google and type in "Aircraft Spruce" and you will find a company that can provide these. I bought a pair from them in '08 for $33.30 each which was about half what they were from Agco at the time.
HTH
Doug View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Doug Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2010 at 7:10pm
Jack and Brian: Thank you for your input. I was able to order the bearings I need from Aircraft Spruce & Specialty Co. Thanks again!
