1.75:1 Rockerarms on 301 & 426
Big Orange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Orange Quote  Post ReplyReply Direct Link To This Post Topic: 1.75:1 Rockerarms on 301 & 426
    Posted: 14 Feb 2014 at 10:12pm
Can you use 1.75 :1 Rockerarms on 301 & 426 without needing to flycut the pistons?
O.P.S. Heads View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote O.P.S. Heads Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2014 at 10:45pm
No.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Orange Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2014 at 9:32am
OK then.    How much of a relief do the pistons need to clear & run.
Post Options Post Options   Thanks (0) Thanks(0)   Quote O.P.S. Heads Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2014 at 4:42pm
That depends on your cam lift and timing as well as where your valves are set for recess or protrusion in relation to the head surface. If you plan to use the stock cam with the faster ratio rockers and stock valve size and depth you could probably get by with a .100" deep relief. If you use a reground cam with the faster rockers and .050 or more protrusion you may need as much as .350" deep depending on the cam grind and where you time it in relation to the crankshaft.
No matter what the combination be sure to measure clearances correctly before final assembly. Use an old piston for machine purposes and install it. Roll the engine over by hand far enough to where both valves open and close with everything assembled and the valve lash set. Use silly putty or whatever you want as a measuring device. Once you decide what is needed you can machine the pistons you will use correctly. You should have a minimum of .060 clearance on the intake and .080 on the exhaust valves. More is good. Too much is not necessary.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Orange Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2014 at 6:50pm
Thank you, I just thought maybe somebody on here may have done this, so I wouldn't have to do all of that. I have done this on race car engines before.
This page was generated in 0.159 seconds.
