WD or WD45 block?
bigcountry48 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigcountry48 Quote  Post ReplyReply Direct Link To This Post Topic: WD or WD45 block?
    Posted: 12 Feb 2014 at 12:28pm
I am building a pulling motor for my wc, it's gonna have a wd45 crank in it that has been restroked, a 170 cam, farmalls h rods, and 4 1/8 inch pistons. What block would this combination fit best in? I have a wd and wd45 block I can use and I was thinking it might be nice to have the pushrod cover be able to come off (like that on the wd block) that way I wouldn't have to pull the motor apart to see if I have a broken rod. Is that a good reason to use the wd block, of should I just use the 45 block? Looking forward to the expert opinions, and you fellas stay warm!
1950 B, 1952 pulling wd, and 1954 wd45
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2014 at 12:39pm
Depends how your rules are. The W201 would pass inspections while the 226 would not if they are picky
Charlie
patrickmull View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote patrickmull Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2014 at 4:31pm
me i used a d17 in mine but like charlie said it depends on the rules at the tracks your pulling at
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2014 at 5:45pm
A WD-45 "W-226" block was/is the factory replacement block for the older/previous W-201 block. There was a point in time, say the mid 1950's, when they simply quit making W-201 blocks and said, here's your replacement block.....take it or leave it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2014 at 5:46pm
Use the WD-45 block......it's stronger than any W-201.
dawntreader74 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dawntreader74 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2014 at 6:49pm
the 45 block is the one to use' it's the wright replacement for wc. you can pull any place with that motor it's right. you cant pull a d17 block in a wc only if theres on rules or there sleeping with the club people. the 45 will be ok anywear been did that. d17 is called a outlaw tractor like casey popcorn pulls'''
Post Options Post Options   Thanks (0) Thanks(0)   Quote patrickmull Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2014 at 7:00pm
can you tell the difference in a series 1 d17 226 or a wd45 226 and i dont sleep with the club people I am a founding member of the club and the club VP and i pull all over the state in usap and natpa pulls
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2014 at 7:06pm
All D-17 blocks from the oldest to the newest are easily identifyable by the strengthening rib that runs horizontally back to front on both sides of the block about 3 inches up from the oil pan rails.
Post Options Post Options   Thanks (0) Thanks(0)   Quote patrickmull Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2014 at 7:13pm
A lot of people don't know that it takes a good AC man to tell in the classes I pull in you can pull a E engine
Post Options Post Options   Thanks (0) Thanks(0)   Quote dawntreader74 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2014 at 7:15pm
yes SR'' mister dr allis' we know one from the other.one is right an one is not.
Post Options Post Options   Thanks (0) Thanks(0)   Quote patrickmull Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2014 at 7:24pm
bring your tractor and come on down and pull with us we like the competition we have 6 pulls a year
Edited by patrickmull - 12 Feb 2014 at 7:25pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2014 at 8:32pm
Well, I was told many years ago, that the WD45 block replaced the WC/WD block. That is kind of a no-brainer. I was also told that into the early to mid 1960's that AC discontinued the WD45 block and then made the D17 block its replacement......plus you had to buy a crankshaft from a D17 to fit your new D17 replacement block. I can't prove it, but this info came from an old retired AC dealer. I don't know of any Antique clubs that wouldn't allow a D17 or E Gleaner engine in a WC, because the performance parts all interchange. You have some weight advantage to stay with the older series engine if weight is a problem.
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigcountry48 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2014 at 8:50pm
Thanks fellas, ill go ahead and use the 45 block seems go just make sense!
Kip-Utah View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kip-Utah Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2014 at 9:48pm
We have a 1941 WC that had a WD45 factory replacement block installed by the dealer in the early 60s. Had all WC internals and the original WC head. Kip
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2014 at 8:14am
Does a WC have a gearing advantage over a WD in these types of pulls?
The WD I used didn't do very well but it has not had a thing done to it either, so I cant say much. Clutch did not slip and basically spun out. So it did not seem to be lacking power.  Not sure I am going to get real serious about pulling, but when you go it would be nice to be more competitive too. I do have a extra 45 block, WD crank, WD flat top pistons and short WD head.
With those parts what would be a good approach to building a good engine on a low budget? I am not a engine builder so any suggestions would be helpful.  I am sure sending it to a engine builder would be one option.
Are there AC pulling engine build 101 classes:)
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigcountry48 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2014 at 11:37am
Just from looking, the rear end on my wc looks bigger than the reared on my wd45. I think it has a different gearing in the rear end and possibly the tranny because, it doesn't have to go through the hand clutch, hydraulic pump, and all that.
mufflerboltz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mufflerboltz Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2014 at 12:28pm
WC is faster then WD, wd is faster then wd45.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2014 at 1:51pm
You can't see the rods with the push rod cover off. All you can see is the push rods and maybe the top of the lifters.
Jasonillinois View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jasonillinois Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2014 at 7:11pm
Per Natpa rules. WD blocks are a replacement for a WC but that is it until you hit div 3.
Which is up to a D17.
Depending on what your rules say. Newer is better as has been pointed out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2014 at 8:21pm
You mean WD-45 blocks are replacement for a WC, right ??   WD and WC blocks are the same.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jasonillinois Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2014 at 8:51pm
No I mean you can use a Wc or Wd block in a Wc. In div 1 or 2.
2t and up you can use anything up to a D17.
If you find a document that shows factory replacement block for a Wc other than a Wd block I would like to see it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2014 at 6:27am
I cannot after all these years have gone by. The supersession of the block P/N's going from the WC to the WD and then to the WD-45 makes perfect sense. Every single engine part from a WC will bolt right onto a WD-45 block......no exceptions. There is zero performance advantage to this change. The change makes perfect business sense for AC. Why continue to produce an old obselete block when the newer one will replace it without any consequence?? And then, the people who define a stupid rule like that, probably allow a WD-45 crankshaft in a WC  !! ...and that would be a performance advantage, where the newer block would not be.  Clearly a poor decision made here with no common sense or deep thought given to it. The Rules commitee must be loaded with 2-banger supporters.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jasonillinois Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2014 at 7:21am
The key to Natpa rules "visual appearance". Just like you can run a leroi head if you can find
One since they look the same externally. Or a 45 crank.
If you can find me info that says they did factory replacements, I can get the rules changed but otherwise it lets
In a lot of other direct drop ins for other makes.
blue924.9 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote blue924.9 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2014 at 8:41am
right there is your problem, if you are not going to get serious about it no wonder you are not competitive, you have to get serious about it, for example when i pull i am always scanning between the flag man my front tires and my back tires. you want to be competitive you have to start paying attention to details,  dont say you dont have enough power, i do very well and usually place in a weight class every pull with a stock motored wd, its not because i have the most power, there are some mean powered olivers and other allis in there but you see, i have found that the more power you have the sloppier you get with weight placement and loose focus on detail, if i can add five pounds i go back to the trailer add five pounds and get back in line to reweigh. the fact that you say it spins out already tells me you need more weight on the back and probably need to lower tire pressure in the rear, dont worry about the clutch  if it is in good condition it wont slip with stock power, and dont be afraid to lug it down, i lug mine till it is almost dead, in fact when i push in the clutch the engine is spinning just fast enough to start refiring as its turning lower rpm than idle. so go out and get the combo you have now working for you, if you think you are doing bad now, more power is going to make it worse
hi my names dan, I am a young guy. i have a problem, i prefer my tractors orange and my clutches mechanical, thanks for letting me share
wi50 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wi50 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2014 at 9:15am
Years ago when I was running the WC in our local pulling association we didn't have much for rules, but had to have a "stock block"  Not much else mattered.  Fellow built a MM Z with a billet alumnium head, overhead cam setup.
I had to run the 201 block, it was almost a problem to use a later #40 block, but it was alright.  I could not use a 45 block.  I would have loved to be able to use D-17 and Gleaner E parts, common and much much stronger but the Oliver guys seamed to have a problem with the Allis guys and made sure we had the right parts.
So being nothing was impossible, but some things take a long time, I hogged out billet caps, girdle, cross bolted the block above the center main and tied the deck to the crankcase by welding the sleeves in.  I cross bolted the new main caps to the pan rails. We didn't have any oil pan restrictions or such like I think some NATPA classes to with a certain thickness girdle.  It was pretty strong and proved to be bullet proof for many many years even taking a hit of NOS when the rules would allow.  At first getting much past 5200 RPM proved more than stock rocker arm shaft could handle, the ends of the shaft that were un supported would just bend up.  Then I made L shaped brackets to go under a head bolt on each end and slugged the ends of the rocker shaft and bolted them down.  That took care of things, much over 6500 RPM though the valves would float.  I had changed valves and springs, different cam profile and ran a downdraft carb with a new intake setup and with a light load in the yard in testing the pipes were ringing pretty good and the recall on the tach said 7050 rpm so I never tried to turn it that hard again, I figured the setup was fine.  I got into the Alcohol Super Stock and just haven't messed with it since.
If I had to build over again, I'd counterweight the crankshaft to take the stress off the block.
I just built this
Edited by wi50 - 24 Feb 2014 at 9:31am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2014 at 6:27pm
I just took a quick look at AGCO Parts Books.com and was pleasantly surprised to see the engine block part number for a "WC" or "WF" or W-201 power unit is 70227049 (no fuel pump) or 70227051 (fuel pump). Then, I went to the "WD" and "WD-45" and W-226 power unit and I'll be darned......the SAME PART NUMBERS !! 70227049 AND 70227051 for the WD and WD-45  and W-226 Power unit!!   Soooo, there you have it. The part number supersession is on the internet and there WAS a way to trace the replacement parts for the engine block. Sign in as a "Guest" and use AGCO-Allis as the brand name. Now, what excuse will the competitors have to complain about ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jasonillinois Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2014 at 8:35pm
I'll talk to the tech man tomorrow about it then. Since it is online I'm not sure
How that will work out but worth a shot.
I'll call my local dealer and see if I can get a paper version from there parts book.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jasonillinois Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2014 at 6:56pm
Per the tech man the replacement block from the agco dealer would not be the same as an Allis mainly due to it not being an oem (as in AC) factory replacement part.
The other point that was made was you can get a lot more clearance for stroke out of a WD #40 block than you can a Wd-45 block.
Not the tech man.. Just an AC/Massey guy
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2014 at 7:13pm
Well, your tech guy just ain't that bright, I guess. Go ahead and try and order a replacement block for a WC or WD or WD-45, and you'll be told the P/N is 70227049 and they are discontinued/no longer available. Been like that for 30 or more years, I'd suspect. The point is, a WD-45 block truly was the authorized REPLACEMENT block for a WC or WD. That's all. There have always been people who make stupid rules and probably always will be people who continue to make stupid rules.  No WC or WD owner should be disqualified for having a WD-45 block. It's just ignorant to do so. The claim of "more stroke room" being available in a late WD block (which is true).... what in Sam Hill does that have to do with calling a WD-45 block in a WC or WD illegal??????? Nothing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dawntreader74 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2014 at 11:13pm
DR'' ALLIS'' WE was right all along the 45 block is the wright motor replacement. don't care what the teck people say the ITPA' TELLS US THE SAME AS WE SAY THE 45 POWER BLOCK IS THE WRIGHT ONE. NOT A COMBINE OR D17 if i go to a hook with one of them motors they will send you home
