max flywheel speed?
JM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JM Quote  Post ReplyReply Direct Link To This Post Topic: max flywheel speed?
    Posted: 10 Feb 2014 at 9:42pm
How fast can you safely turn a stock wc flywheel?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2014 at 5:06pm
Antique clubs generally always limit maximum engine RPM's. Some are stock.....some are 10% over stock......some are 20%, 30% etc.  Many insurance companies who insure tractor pulls, require a 3,000 RPM ceiling for safety purposes on tractors that are considered "stock". I don't really know what you're a thinkin' , but a new WC flywheel with no cracks whatsoever is surely safer than a 70 yr old flywheel with dozens of cracks. That being said, I've never been afraid to wind a WC to 3,000 RPM, but that's just me. When I say that, I mean with a good clutch and pressure plate that is NOT slipping at 3,000 RPM.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2014 at 6:38pm
Yep, When I pulled my 45 engine out to replace the clutch, it about scared me hafl to death. Cracks in the flywheel went all the way thru and were 3 to 4 inches across the face of the flywheel. I don't think I would want to be around that flywheel at 3K. I wouldn't want to have to fix the thing if the flywheel did come apart.
 Add a little slipping while pulling and the cracks can go deep and long real fast.
This page was generated in 0.122 seconds.
