what tire will pull better?
JM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JM Quote  Post ReplyReply Direct Link To This Post Topic: what tire will pull better?
    Posted: 10 Feb 2014 at 7:19am
If you had a choice between 11.2-38,11.2-36 or 14.9-28 in a stock class, what would you run? Would a wc with a fresh d17 engine spin out 11.2-38 @ 3500lb? Thanks---
XT in pa View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote XT in pa Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2014 at 10:12am
11.2x38 yes it will spin them. My 17 will spin 18.4x38 bfg in 5000lb class in 2nd low I'm just running the 4 1/8 overbore kit in mine with a lil head work.
190XT,D17and 7045
WildBill View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WildBill Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2014 at 1:58pm
I wud run 14.9 28's . I did well with those in a firestone field and road . Little easier to find . Will be no troubles with the 17 engine
Allis fan for life !   B,C,2-WC'S,WD45G,D19G,190xt ,LLSS 8010, terra tiger refurbished
EricSWPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote EricSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2014 at 7:34pm
Both my WC will spin 13.6 38 tires in 3500 4000 and 4500 in most cases
Post Options Post Options   Thanks (0) Thanks(0)   Quote EricSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2014 at 7:37pm
I should state one has a gleaner e engine the other is built with a 45 crank and dynos 53hp this one will spin in 5500 farm stock most of the time though it has a Rc rear end
blue924.9 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote blue924.9 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2014 at 4:58pm
depends on track condition, a briggs and stratton will spin 38s if the track conditions suck
hi my names dan, I am a young guy. i have a problem, i prefer my tractors orange and my clutches mechanical, thanks for letting me share
Post Options Post Options   Thanks (0) Thanks(0)   Quote EricSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2014 at 6:24pm
One other advantage in our club a division is our stock class the rules state 1st gear only with a WC on 38s you'll have an nice speed advantage with those kind of rules. Just a thought
JM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JM Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2014 at 7:29pm
Just located a set of 14.9-28 firestone all traction field and roads. Guy says the have 90-95% tread left, going to get them next week.
What is difference between atfr and tfr? Do they have more bars?
Are they good pullers? Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote WildBill Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2014 at 9:13am
It's cool you are able to find tires !! But they are too tall yet. Are they old and cured ? Just remember full lug tires piles dirt infront of the buck board. Finding the right tires is tuff!! Especially when they tripled in prices !
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2014 at 7:14am
Taller the better.   MACK
This page was generated in 0.151 seconds.
