Henry Mark IV Backhoe
T JOHN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote T JOHN Quote  Post ReplyReply Direct Link To This Post Topic: Henry Mark IV Backhoe
    Posted: 06 Feb 2014 at 9:37pm
How can I remove the swing cylinder from the backhoe? I have removed the two large nuts from the studs that hold the cylinder to the platform, thinking that it would lift off, but nothing moves. Where can I get service manual for this unit?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2014 at 9:33am
Is this the Rotary Piston type Cessna unit ? If so the 2 studs are a expanding type that fit into bore in casting which is suppose to prevent unit from turning .
 The shaft  is spline d and fits into machined area of boom. Using pry or hydraulic force from underside should raise unit out of splines
This page was generated in 0.939 seconds.
