Hydraulic Oil for 715 AC backhoe
oldmtnrick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote oldmtnrick Quote  Post ReplyReply Direct Link To This Post Topic: Hydraulic Oil for 715 AC backhoe
    Posted: 06 Feb 2014 at 7:01pm
Just bought this Allis Chalmers 715 Backhoe. The Operators Manual shows in the listing for the Hydraulic Oil that it takes SAE5W-20 for cold weather and SAE20W-50 for warmer weather. The question is does hydraulic oil come in a SAE designation?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2014 at 7:48pm
You could use 10/30 or even Universal Tractor Fluid with no problem .
Or if you can get it at right price ATF.
 Most Hyd oil R&O # does not have all the anti-wear or anti foam additives the above do
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2014 at 8:21pm
We use Universal Tractor FLuid-- 5 gallon buckets at local Farm Store.
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2014 at 10:13am
I've used universal tractor oil in my 715 and 715B for 35 years.
This page was generated in 0.666 seconds.
