HD5G temp gauge - testing?
Osage_Orange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Osage_Orange Quote  Post ReplyReply Direct Link To This Post Topic: HD5G temp gauge - testing?
    Posted: 21 Feb 2010 at 4:35pm
The temperature gauge, sending unit, and connecting wire looks complete. However, it has not worked since I owned this machine (several years).  What is the best way to check out the circuit to see which component is not working?
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2010 at 10:48am
on an electric gauge.  check your connections to make sure your gauge is getting voltage.   probably 12V to one side.  the opposite side should go to the sender, try removeing the sender wire and grounding it.  It should peg up or down depending on how its set up, if not probably the gauge is bad or its not getting voltage, or sender wire is bad.  if it moves your sender is bad
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2010 at 9:46pm
The HD5 used a mechanical temp gauge,  I used a IH gauge that i found at the right price to replace my AC non working one.
This page was generated in 0.887 seconds.
