D 15
michaelwis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote michaelwis Quote  Post ReplyReply Direct Link To This Post Topic: D 15
    Posted: 21 Feb 2010 at 10:53am
MY D15 is either gonna have to have a major oh done on the engine... or do i get an old combine engine .?. what model would fit ? looking for ideas?
btw . it is a series 2
costs ?
Edited by michaelwis - 21 Feb 2010 at 11:22am
WD WD45 DIESEL D 14 D-15 SERIES 2 190XT TERRA TIGER ac allcrop 60   GLEANER F 6060 7040.and attachments for all Proud to be an active farmer
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2010 at 11:49am
Don't think you will find a Gleaner with a 15 engine in it. Maybe a power unit if your lucky. But best bet is just rebuild your old engine.
GregLawlerMinn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2010 at 6:11pm
The D15 SII has the 160 CI gas engine. I think that there were some Allis dozers that shared the 160 CI engine. The 149CI engine from a D14 is a drop-in replacement, altho, there would be a few ponys lost. Check with Tony/Barb, Jim Danforth, and a few other of the vendors for costs on the rebuild kits.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2010 at 9:45pm
The 149 was only used in Series I D15s, and had higher compression than the 14.  As JC said, your best bet is to rebuild the one you have.
NCWC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NCWC Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2010 at 9:59pm
You will have to look on the side of the engine and see if there is a 149 or a 160 on the side of the engine .. there is a big difference on the cost of the rebuild! Message me.
B,C,CA,RC,WC,Unstyled WC,WD,WD-45,B puller, WC Puller,WD Puller, WD-45 Puller
JimD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimD Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2010 at 10:05pm
Yep BIG difference.  I can get both, but the 160 is a lot more.  The 160s are out there in power units, forklifts, and a few other applications.  You probably are still better off rebuilding yours though.
I love the sound of my D15 II.  Nothing else sounds like it.  If you have a series II, it came factory with a 160.  You can comfirm as has been posted by looking at your engine serial number, it will start with the displacement.
JimD
olijean View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote olijean Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2010 at 7:46pm
I have a D15 series 2 160 block rebuilt the whole motor. the only place to get a rebuilt kit is allis chalmers. When i got done there was $2600 in the whole motor. Best of luck.
Rogers View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rogers Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2010 at 8:21pm
The series II is the 160 engine. A rebuild kit will probably run around 900 to 1000 dollars. You may find one for less.
Think for yourself and be your own expert. Be willing to change your mind; however, willingness to change your mind doesn’t mean that you will. Blindly following any path is the pinnacle of insanity.
