|  | This site is not affiliated with AGCO Inc., Duluth GA., Allis-Chalmers Co., Milwaukee, WI., or any surviving or related corporate entity. All trademarks remain the property of their respective owners. All information presented herein should be considered the result of an un-moderated public forum with no responsibility for its accuracy or usability assumed by the users and sponsors of this site or any corporate entity. | |||||
| What other model engine will fit a 170 gas? |
| Post Reply   |
| KurtDE   Bronze Level     Joined: 19 Sep 2009 Location: Hilton New York Points: 83 |  Post Options  Thanks(0)  Quote  Reply  Topic: What other model engine will fit a 170 gas? Posted: 20 Feb 2010 at 10:56pm |
   Looks like I will need an engine for a 170 early gas. What will fit? any combine engines and what is required if it does? So far the parts needed to repair the original are oil pan, oil pump, oil suction line and screen, camshaft, lifters, cam bearings, cam shaft cover, 1 connecting rod, 1 sleeve and I have'nt even pulled off the head or the crankshaft!
 Kurt | |
| Kip-Utah   Orange Level     Joined: 14 Sep 2009 Location: Southern Utah Points: 918 |  Post Options  Thanks(0)  Quote  Reply  Posted: 20 Feb 2010 at 11:09pm |
   Kurt, you could use an engine out of any E model Gleaner, 175 Gas, or Series 3 or 4 D17. Kip
| mlpankey   Orange Level   Joined: 13 Sep 2009 Location: Vols country Points: 4580 |  Post Options  Thanks(0)  Quote  Reply  Posted: 21 Feb 2010 at 9:55am |
   well theys only two items listed that a new overhaul wouldnt need in my opinion . they are the oilpan and cam cover. having a new clean oil system is the life of any engine build. Edited by mlpankey - 21 Feb 2010 at 9:56am | |
| E7018   Bronze Level   Joined: 07 Dec 2009 Points: 167 |  Post Options  Thanks(0)  Quote  Reply  Posted: 21 Feb 2010 at 10:25am |
   I am putting a F Gleaner engine in a D17. (If I ever get time to work on it.)  I think it will work out well.  Allis did use some Perkins 4-236 diesel engines in 175 tractors. That is the engine in a Massey 410 combine. I dunno what other parts you would need to make that work. My old D17 engine would be available but it has a bearing tightening up on the crank. So, it would need majored with crank ground. | |
| Lester   Orange Level   Joined: 08 Jan 2010 Location: Indiana Points: 521 |  Post Options  Thanks(0)  Quote  Reply  Posted: 21 Feb 2010 at 3:11pm |
   The 236 and the 248D was never used in the MF410 combine.
| Post Reply   | |
| Tweet |
| Forum Jump | Forum Permissions  You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You cannot vote in polls in this forum |
