D17 Series 4 gas starting wide open
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChuckLuedtkeSEWI Quote  Post ReplyReply Direct Link To This Post Topic: D17 Series 4 gas starting wide open
    Posted: 20 Feb 2010 at 2:03pm
Picked up a D17 series 4 that wasn't running.  Got it to fire up today.  Just put some gas in it, cranked it for awhile with the wire off the coil to make sure oil pressure built back up cause it had been sitting for awhile.  Checked for spark and had it and as I was checking for spark, the ole girl tried starting on three cylinders.  Put the other spark plug in, and she started right up.  Problem is it was running wide open.  I looked in the manual and it wasn't really clear, but I am guessing that idle is with the throttle lever at about 1 o'clock and as you pull it down it opens it up.  I tried it in all positions and it's just wide open.  Linkage is moving back and forth to the governor.  Did not check the carb side to see if it is moving.  Maybe the carb is gummed up and it's stuck open.  She ran for about a minute, and then conked out.  I haven't cleaned the carb or sediment bowl yet, so I am poor word choiceuming she's full of crud somewhere.  If I have time, I will post some pictures of her.  She's in pretty good shape but needs some work.   I think the hourmeter says a little over 7000 hours so she has worked alot back in the day.
Edited by ChuckLuedtkeSEWI - 20 Feb 2010 at 2:05pm
Denis in MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Denis in MI Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2010 at 2:12pm
see if the linkage that goes from the governor to carb is moving my WD did this and the shaft had siezed where is comes out of the governor, It might be the carb butterfly is seized or something is stuck in it. These are just places I would start, The engine stoping could be from crud in the fuel system but I doubt that is why it ran wide open.
1938 B, 1945 B, 1941 IB, 1949 C, 2 1938 WCs, 3 1950 WDs, 1951 WD, 2 1955 WD45, 1957 D-14
Chris (swIA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris (swIA) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2010 at 3:05pm
Chuck, if the linkage is free to the carb, you might pull it off and check the throttle plate. My WD did this a couple of years ago and I found that brpoor word choice screws were used to attach the throttle plate during a carb rebuild and had broken. I found the plate wedged in the head.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris (swIA) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2010 at 3:08pm
It must not like that soft yellow metal for screws. Needless to say i replaced them with steel screws.
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2010 at 4:03pm
Chuck,  After you've checked out what the other guys have told you and everything checks fine there,don't rule out that the governor might have thrown the weights. The D17 likes to do that a lot. Been there,done that.  Rick
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2010 at 10:15pm
Rick - I was thinking the same thing.  Mike
1968 Gleaner EIII w 10' & 330
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
1956 All-Crop 66 Big Bin
JoeO(CMO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(CMO) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2010 at 7:41am
Before you get all your tools out, check for mud dobbers deposit on the back side of carburetor
