tires
allispuller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allispuller Quote  Post ReplyReply Direct Link To This Post Topic: tires
    Posted: 19 Jan 2014 at 7:46pm
Has anyone ever used 16.9x30 long bar short bar tire? I know where there is a good set and was wpndering if they would be worth my time trying.
2wise4agm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 2wise4agm Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2014 at 8:28pm
I've never used them, but I've heard pullers around here talk about them. Only bad things to say about them
BennyLumpkin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2014 at 8:39pm
Long bar short bar tires aren't any good for pulling.....
Central PA Allis Express
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2014 at 3:23am
They are the worst possible tire out there for pulling or farming!
XT in pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote XT in pa Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2014 at 5:01am
We have a set of Armstrong 18x38 on 18 inch rims. They are real sharp from road wear. They are on a 806 right now and do awesome. Better the more weight you put to them. I had them on the xt before and had to drop a gear cause they hooked up so good. Other results may very. I'd buy another set of them for sure.
190XT,D17and 7045
Post Options Post Options   Thanks (0) Thanks(0)   Quote allispuller Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2014 at 5:14pm
What tire would you guy suggest for a 3.5 mph class
Post Options Post Options   Thanks (0) Thanks(0)   Quote 2wise4agm Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2014 at 6:01pm
Can u run radials?
Post Options Post Options   Thanks (0) Thanks(0)   Quote allispuller Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2014 at 6:14pm
I havent seen anything that says i cant run radials
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2014 at 6:18pm
I know of zero Antique clubs that allow radials. Go ahead and put some on and if you start winning, at the next Rules meeting they will be banned.
cwhit View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cwhit Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2014 at 6:55pm
You need to get a set of  Firestone 15.5-38s. Better yet, find 2 sets, call me and I'll take the second set off your hands.....
Post Options Post Options   Thanks (0) Thanks(0)   Quote allispuller Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2014 at 7:06pm
The only thing i see is if i get 15.5-38 the ground speed chart i have found shows 1st gear around 4 mph and i need to stay at 3.5
Post Options Post Options   Thanks (0) Thanks(0)   Quote cwhit Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2014 at 7:14pm
You won't be able to open it up until you get a load on the engine (about 1/2 - 2/3 down the track ) by then you'll be glad you have 38s.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 2wise4agm Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2014 at 7:32pm
Dr is right. Most clubs don't allow radials. But if by some chance you can run them, they'll make a big difference. The firestone 23* is the tire of choice around here. Firestone f151 is pretty popular in a bias ply.
Gar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gar Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2014 at 6:49pm
I'm pretty sure the largest antique tractor pull in the world allows radials. Tunica
Post Options Post Options   Thanks (0) Thanks(0)   Quote 2wise4agm Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2014 at 6:51pm
Rules are pretty loose at tunica compared to most clubs.
