S dozer |
ac fleet
Joined: 12 Jan 2014 Location: Arrowsmith, ILL Points: 2337 |
Topic: S dozerPosted: 19 Jan 2014 at 7:15pm |
JC-WI
Joined: 11 Sep 2009 Location: wisconsin Points: 34631 |
Posted: 19 Jan 2014 at 9:16pm |
Where did it go to?
You said it had the oil engine, You mean it still had the injection pump on it ... and not coverted to carb, correct?
The truth is the truth, sugar coated or not. Trawler II says, "Remember that." |
ac fleet
Posted: 20 Jan 2014 at 12:48pm |
It had carb on it and was battery dist. ign---12-volt,--starter was also 12-v.
I sold it to a guy down the road for parts for his hd-10 (track parts and whatever else that fit)----thanks; ac fleet |
JC-WI
Posted: 20 Jan 2014 at 3:22pm |
If I am not mistaken, the oil engine was a higher compression than the gasolene burners were. So when they converted the oil engines to gas /carb, it would have more power.
Did yours still have the injection pump hanging on it? and injectors in the head?
If I remember right,, the SO was mallory ignition too.
WSO were like finding hens teeth...
Does the fellow still have the left overs of it? Thanks
ac fleet
Posted: 20 Jan 2014 at 9:16pm |
No pump or injector remains!---just looked like one very large gas engine!!---still had a starting tank and plumbing with fuel valves to turn on big tank and turn off little tank after engine warmed up!----would have to look in the book that came with it to see what the cuin of the engine was! thanks; ac fleet
JC-WI
Posted: 20 Jan 2014 at 10:18pm |
The engines cubes were 675... 5 3/4 x 6 1/2.
The origional oil engine would have had a canister of about a quart size with a rocker arm plunger pump on top that would have sprayed gasolene into the intake throat while you cranked it over to start it and you kept stroking the pump till the engine started and was running on diesel.
What it sounds like was a lower compression engine for dual fuel set up... and I don't remember seeing anything about those engines coming with that option.
I have an S that had the engine rebuilt and then had grousers refurbished with weldons and then they started redoing the steering clutches... and they left water in the engine and froze it. Thats when they decided not to bother putting the crawler back together and I don't have all the parts required to renew the back end. Steering clutches were left exposed. and the crack in the block is from end to end. So I was looking.
