HD5
billyschulz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote billyschulz Quote  Post ReplyReply Direct Link To This Post Topic: HD5
    Posted: 18 Jan 2014 at 5:49pm
I'm looking for a radiator for a HD 5 crawler anyone know of anything that will interchange or one for sal
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2014 at 6:39pm
I used a radiator from a 46 Chev car in a machine until I could find proper unit. The overall size was a good fit in mounting area - but the cooling capacity was not . You might be able to find something in that size in a 4 + core unit that will work.
Dozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dozer Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2014 at 10:29am
I do not know if this option exhists today but years ago I took my damaged industrial tractor radiator to a radiator shop and had a new core installed. The top and bottom tanks were not damaged so the shop was able to create a new core. Some of these old time skills may still exist in rural areas.
Andrew_D View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Andrew_D Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2014 at 10:55am
Yup, local rad shop here would rebuild it if needed. If you needed a tank, that's where it gets tricky. But if the tanks are OK, they should be able to re-core it. Be sure to specify what it is for. Would hate for them to think that it is a vehicle with 60mph wind helping to cool!
Try looking specifically for a "rad shop".
Andrew
Post Options Post Options   Thanks (0) Thanks(0)   Quote Andrew_D Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2014 at 11:01am
Andrew
Just did a google search using the OP's location and "rad shop":
Bays Radiator Shop, Bloomfield, IN
Yoder's Radiator Repair, Cannelburg, IN
Can't comment on these shops though...
Andrew
Horseman8 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Horseman8 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2014 at 12:13pm
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2014 at 7:07pm
For the record, I had a D-15II recored, a coupla years ago, $450+/-.  I know it's likely a smaller radiator, but it's a point of reference.
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2014 at 9:21pm
Local radiator shop here takes measurements of the core and then calls up a place in Mi. to get new cores made... and you don't get to keep the old core... shop wants that for their own copper and brass recycling... Says it offsets the cost of the new core.
rwhendrix View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rwhendrix Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2014 at 7:36am
@billyschulz
Hi, I dont have a spare HD5 that I know of for you, but Im here in Indiana too. I have an HD5G with front loader. I will let you know if I come across anything nearby for you.
