616H Hydrostatic oil capacity
Brampton 02 gt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brampton 02 gt Quote  Post ReplyReply Direct Link To This Post Topic: 616H Hydrostatic oil capacity
    Posted: 18 Jan 2014 at 9:36am
Does anyone know the capacity? I am going to give it an oil change. I was going to use a case/nh hytran I have. I need to get an owners manual
thnaks
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2014 at 8:55am
It has a Eaton Hydrostatic unit - think it is around 2 1/2 qt . I used ATF in unit . it does have the vent cup where you add oil till full.
 The Hydrogear Transaxle  in another mower i have uses 20/50 motor oil  and the Vickers unit in my New Holland uses 10/30
John Ontario Canada View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John Ontario Canada Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2014 at 10:26am
Call Country Air and Repair in Moorefield. They are not far from Mount Forest. Very knowledgeable people. They are a Simplicity dealer.they can tell you the info and might even find you a manual. 1 519 638 8941.   Good luck.     John.
rooster View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rooster Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2014 at 8:38am
Mine has the filler neck and cap. sombody has put 5w30 and 0w20 and what ever was laying around in it and when it warms up it getts sluggish. what should i do.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2014 at 10:49am
Try 20/50 - to see it it helps -
