hd5g hydraulic pump |
| Author | ||
baker84
Topic: hd5g hydraulic pumpPosted: 14 Jan 2014 at 11:09am |
So the hydraulic pump in my hd5g is worn out. And i'm trying to find out what its displacement is?
This is the pump I'm looking at. Any suggestions would be great. Thanks
| Sponsored Links | ||
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42270 |
Posted: 14 Jan 2014 at 11:25am |
Flow on the Hydreco pump is around 30 GPM at 1800 rpm and around 1200 psi. from what i remember .
Early HD5G used a vickers vain pump but later was the gear pump
baker84
Posted: 14 Jan 2014 at 11:29am |
Mine does have the hydreco gear pump. But looking up the pump numbers on the data plate haven't gotten me anywhere.
Dozer
Joined: 16 Aug 2011 Location: SW New York Points: 689 |
Posted: 14 Jan 2014 at 11:51am |
You should take your pump off and see if you can have a hydraulic repair shop rebuild it. Thr HD5 pump is large because it has to deliver large volume at low RPM. Max governed speed of your 2-71 GMC is 1800 RPM. The pump is designed to be rebuilt. It has wear plates with shim gaskets to compensate for end wear on the gears.
Good luck |
baker84
Posted: 14 Jan 2014 at 11:55am |
No it can't be rebuild, one of the bearings has started to go out chewing into the gears bearing surface and into the pump housing. It is shot.
baker84
Posted: 14 Jan 2014 at 1:02pm |
Well looking around the internet I found this handy gear pump displacement calculator.
And in measuring my already taken apart pump it looks like it is about a 3.46 c.i.r. pump So what do you all think about this pump? Is there a better place to purchase a pump from? I know I will have to adapt any pump I purchase because the original has this huge weird mounting flange on it. |
Andrew_D
Joined: 28 May 2013 Location: Newdale,MB,Can Points: 148 |
Posted: 14 Jan 2014 at 3:13pm |
I'm not a hydraulic expert by any means, but the displacement looks alright. And it is rated continuous at 1800rpm which an earlier poster mentioned is the speed of your engine. I would think it would be fine.
Yes, it will require some adapting, but that's almost true of all repairs on these ol' machines! Will it physically fit without major modifications? Manufacturing mounting brackets are one thing, but major changes just because a pump is too wide or too tall or too long or because the hoses enter/exit differently can really be a pain! Andrew Edited by Andrew_D - 14 Jan 2014 at 3:16pm |
DMiller
Joined: 14 Sep 2009 Location: Hermann, Mo Points: 35679 |
Posted: 14 Jan 2014 at 4:36pm |
Coke, I have the used pump off my second HD7G, Similar or same?
P/N 73029952 Hydreco type. Old P/N would have been 029952 Actually after digging thru the parts list is a Tyrone 70655190 Completely different. Edited by DMiller - 14 Jan 2014 at 4:39pm |
DMiller
Posted: 14 Jan 2014 at 4:41pm |
Did a p/n search for the earlier style for HD6/7G 73029952;
73029952 by FIAT ALLIS-REPLACEMENT - FIAT ALLIS ... - FinditParts www.finditparts.com › Manufacturer › FIAT ALLIS-REPLACEMENT FinditParts has FIAT ALLIS-REPLACEMENT parts like 73029952 for Trucks, Busses, Trailers, and Other Vehicles. 73029952 by INDUSTRIAL GENERAL MANUFACTURES - FIAT ... www.finditparts.com › ... › INDUSTRIAL GENERAL MANUFACTURES Only orders with an item total over $50.00 are eligible for this offer. 73029952 by INDUSTRIAL GENERAL MANUFACTURES - FIAT ALLIS HYDRAULIC ... FIATALLIS part number 73029952 for sale - Newtonville, MA, USA ... www.rockanddirt.com/parts-for-sale/FIATALLIS/.../invnum=194926076 FIATALLIS part number 73029952 in Newtonville, MA Quality Heavy Equipment Parts For Less. Search from 1000's of listings for FIATALLIS parts updated daily ... Replacement Hydraulic Pump for HD6G; PN: 73029952 www.oilfieldsupply.com/product.php?pid=80098&cid=40 Quantity. Description. Replacement Hydraulic Pump for HD6G; PN: 73029952. Details. Part Number: 73029952. Manufacturer: Fiat Allis Delivery: 1 - 2 DAYS 73029952 - Fiat Allis Several - Parts for All partsforall.com › Parts for Sale › Heavy Equipment Parts - For Sale May 18, 2012 - FIAT ALLIS REPLACEMENT HYD PUMP; Fits Models: HD6G. PARTS - PUMPS - FIAT-ALLIS - ALL - Contractors Hot Line www.contractorshotline.com/.../Equipment.cfm?...FA...ALLIS 137 records - PARTS - PUMPS - FIAT-ALLIS - ALL - Contractors Hot Line has new and used ... Details, 73029952 FIAT ALLIS REPLACEMENT HYD PUMP ... 73029952 FIAT ALLIS REPLACEMEN - Tractor-Part www.tractor-part.com/search?q=73029952%09FIAT+ALLIS...sitemap... Tips for searching like a pro. Don't see what you're looking for in your search results? Here are some basic tips and tricks to help you find just what you want ... 73029952 - Tractor-Part www.tractor-part.com/search?q=73029952 5+ items - Part #, Make, Model, Description, Price, Location, Dealer ... Description Location Dealer Phone. FIAT ALLIS REPLACEME KY IHM Used Parts 888-821-1817 FIAT ALLIS REPLACEMENT HYD ... FL E Forklifts 888-578-9068 All I did was type in Allis and the p/n, have you tried this? Edited by DMiller - 14 Jan 2014 at 4:43pm |
Coke-in-MN
Posted: 15 Jan 2014 at 12:31am |
I had found a Vickers pump for the HD5 but it took a special adapter to fit into the front pulley to drive it . I checked every place I could find for that part and came up blank.
I returned the pump to the guy i got it from - he had been running 3 HD5G machines in their gravel pit and concrete operations but had sold 2 of them at the time and the unit they were using had the Hydreco pump. The cast front mount on the pump makes it hard to adapt and the placement below the hard nose and belly pan gives limited space to adapt . I now have a extra pump I picked up several years back but the wear plates showed scoring and so far I have not got around to doing much with it. The casting, shafts, and gears are all good but unsure of seals. Odd as about 12 years back I snow plowed for a hyd shop and took my hyd pump in to see if they could get me a little more pressure and check it over . Said pump was shot and funny it moved any oil at all - so i lapped the side plates and cut down some on the clearances and it's worked since .
Andrew_D
Posted: 15 Jan 2014 at 5:54am |
Was just looking it over again and wondered about the pressure? The pump says it will produce 3600psi. Can the valves, cylinders, etc on the ol' girl handle this much pressure? I thought these older machines were often designed to run lower pressure hydraulic systems - usually in the 1200psi range. Andrew |
TramwayGuy
Joined: 19 Jan 2010 Location: Northern NY Points: 11858 |
Posted: 15 Jan 2014 at 8:34am |
3600 PSI is awful high for a gear pump. I think that 2000 PSI would be reasonable for a maximum.
