ground speed
allispuller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allispuller Quote  Post ReplyReply Direct Link To This Post Topic: ground speed
    Posted: 12 Jan 2014 at 3:26pm
Was wondering if anyone has a groundspeed chart that has the ground speed for a WD45 with 16.9x26 tires and stock rpms and 10% and 20% over rpms
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2014 at 5:02pm
No one can give you an EXACT speed. Why?? because there are too many differences in tire brand actual diameters.....Goodyears are usually smaller diameter than a Firestone and an Armstrong is oftentimes the biggest. Then, there's the matter of a worn out tire versus a new tire.  There's always an issue with wheel slippage. The 16.9 x 26 should be very close in diameter to a 14.9 x 28 which is a WD-45 tire size.  That would make low gear 2.5 MPH@1400 RPM.....3.1 MPH @ 1700 RPM.........3.3 MPH @ 1870 RPM.........3.6 MPH @ 2040 RPM.
cotncrzy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cotncrzy Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2014 at 6:38am
I run them on mine one season, works perfect for a 3.5 or even 3.5 mph class. I was running 2050 rpms's I would blow the horn but by the time I got to the barrier just enough slippage occoured to make for no ajustment.
C, WD45,WD puller, 185, 200, 7060 Red Belly, 7060 Black Belly,8010, and a R52 Gleaner, AND PROUD OF THEM!
blue924.9 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote blue924.9 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2014 at 8:19am
i will add one thing that you may or may not know already, remember these speeds are at load. my first pull this season had a 3.5 mph limit. i was thinking 2.5 mph in first i will be all good, and for that pull i was, then i go to my second pull and it has a 2.5 mph speed limit, perfect right? wrong, see in 3500 pound class in the beginning there is not enough weight to pull the rpms down to loaded rpm, so instead of running 1400 rpm i was running closer to 1800 rpm, and since we dont have the first 100 foot rule i got horned, luckily you get more than one horn in our association or i would have been disqualified, just something to think about
hi my names dan, I am a young guy. i have a problem, i prefer my tractors orange and my clutches mechanical, thanks for letting me share
Post Options Post Options   Thanks (0) Thanks(0)   Quote cotncrzy Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2014 at 6:09pm
We can blow the horn all the way to the barrier. Just cant after you pass it. Some are at half track some 100 foot.
Fields View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fields Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2014 at 7:26pm
Load Radius X RPM divided by 14055.
16.9-28 25.6
Std rpm 1720 3.1 mph
10% 1892 3.4 mph
20% 2064 3.8 mph
30% 2236 4.1 mph
Post Options Post Options   Thanks (0) Thanks(0)   Quote allispuller Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2014 at 7:28pm
I run firestone field and roads now have had issues sometimes with the tractor not wanting to hook up. Since most places i pull are either low gear only or 3.5 mph so im looking for a tire size that would give me 3.5 mph in 1st gear at around 10% over factory rpms
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fields Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2014 at 7:32pm
my book didn't show 16.9-26. so 14.9-28 is 3.0, 3.3, 3.6, 3.9,  so my guess is in between these.
