need an honest opinion on tires |
mufflerboltz
Joined: 03 Oct 2012 Location: New Glarus, Wi Points: 371 |
Topic: need an honest opinion on tiresPosted: 09 Jan 2014 at 6:57pm |
Will 16.9x34 tires be to much on a wc with a good built 244 ci engine?
Fields
Joined: 25 Apr 2011 Location: Reedsburg, Wi Points: 359 |
Posted: 09 Jan 2014 at 7:18pm |
wel gearing ground speed book shows 16.9-34 the same ground speed as a 13.6 or 15.5-38.
but has a bigger contact area 229 square inches. My local rules have changed. I might be willing to sell my Shurman Underdrive.
EricSWPA
Posted: 09 Jan 2014 at 8:48pm |
I'd think in 3500 and 4000 lb it would be okay unless the sled is ridiculous.
mufflerboltz
Posted: 11 Jan 2014 at 7:13am |
Fields, what is the mph for a WC with 16.9x34 running 2000rpm?
EricSWPA
Posted: 11 Jan 2014 at 9:53am |
My unstyled with 13.6 38 at 1850 rpm i got a horn at 4mph off the line in first gear are club runs 3mph so I have to idle down the track a good ways before you open it up too much are fair pull is 4mph that's how I know it will go over 4mph
mufflerboltz
Posted: 11 Jan 2014 at 12:03pm |
So it would be just about right for a 4 mph class, sweet that's what I'm shooting for.
cotncrzy
Joined: 07 Oct 2009 Location: TENNESSEE Points: 599 |
Posted: 13 Jan 2014 at 6:26am |
My WD runs 5.2 in 1 st gear @ 2000 rpm under no load with full cut 16.9x34. It's impossiable to pull 3, 3.5 mph classes. 4 mph is good at 15 to 1600 rps. the trouble down here on this clay is 244 cid wont come back whe the sled loads the rear wheels and increases traction. We bumped the cid. , now pull, 4, 6 and 8 mph! That equates to First, second, and Third gears in the 3500, and 4000# classes, after that we back to first gear.
If you pull on loose tracks that allow for slippage you will be ok, but if you are going to be on tight "power" tracks read my post carefully... Just my honest EXPERINCE, not opinion
C, WD45,WD puller, 185, 200, 7060 Red Belly, 7060 Black Belly,8010, and a R52 Gleaner, AND PROUD OF THEM!
Juiceman
Joined: 26 Aug 2013 Location: West Virginia Points: 110 |
Posted: 13 Jan 2014 at 8:45am |
Cotncrzy.. How heavy do you guys usually pull?
cotncrzy
Posted: 13 Jan 2014 at 12:45pm |
Pulled 5500 and run oot of room for weights. Still had power...
