7050 1 5/8 WATER HOSE NEEDED
DarrylinWA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DarrylinWA Quote  Post ReplyReply Direct Link To This Post Topic: 7050 1 5/8 WATER HOSE NEEDED
    Posted: 18 Feb 2010 at 6:55am
I was at the local Agco  Dealer yesterday and and am looking for the 1 5/8 water hose that is a 90 degree going from the top of the head to the water pump on the left side of the motor. It is about 3 inches long on bothe sides of the elbow. It has the 2 small wire bands that hood the hose on. There microfish and parts book online does not show it. I know it exists. It is the 3700 motor maroon belly and the hose is painted marron from the factory.
Any part numer would be great so I can reorder it or go down to the Car Quest or Napa through the shelves.
Thanks in advanced, Darryl Krause in Lynden WA.
B 10 Custom. Serial # 1001 D21, First D21 built 69 #4498 and Last D 21 Built #4609. 1946 MM UTU. And 2000, 2005 Pete's. AC custom Hauling.
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2010 at 7:10am
I found it online with no problem
Its on pg 62
COOLING SYSTEM - THERMOSTAT
Bypass hose pn 74255459
jmm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jmm Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2010 at 9:25am
say.. where did you find a parts catalog online?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2010 at 9:44am
jmm - click on the link below.  You must use Internet Explorer, Firefox won't work on the site.  Use the "Guest User" box to access the parts books.  HTH.  Mike
http://www.agcopartsbooks.com/EpsilonWeb/login.aspx?region=NorthAmerica
1968 Gleaner EIII w 10' & 330
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
1956 All-Crop 66 Big Bin
